Ethernet Products
以太网
TS965
Hello, Mr Intel 1、 Yes, I have purchased a wgi210it Ethernet product. I have taken it to the motherboard for testing. After the motherboard is installed, the model displayed on the computer is Intel (R) i210 gigabit network connection 2、 However, I suspect that the goods are wgi210at, because I have made appearance comparison and label comparison. Now I use the method of testing the model after the machine is installed. This model is displayed. Is this at or it code 3、 I saw the difference between at and it that you gave me. I can only distinguish wide temperature, but I still can't. is there any direct method to inspect the goods Could you please tell me. thank you
