Ethernet Products
5304 Discussions
82579V appears as 82579LM
User1587852407382730
my system consists of a ASUS board P8Z68-V PRO with the network controller Intel 82579V.
I have the problem that the network controller is not recognized correctly every time Windows is started. It appears to have started after the upgrade to WINDOWS 10 1909.
It is exactly as described in this post: https://www.intel.com/content/www/us/en/support/articles/000028256/network-and-i-o/ethernet-products.html
After clicking on "scan for hardware changes" in the device manager, the device is recognized as an Intel 82579V and works again until the next boot of Windows. And I need to repeat to procedure to again get the network adapter to connect.
Thanks for your help.
n_scott_pearson
This is an 8 year old board. Things like this are going to happen as aging takes its toll. If replacing the board is not in the cards, your only choices are going to be to add a PCIe or USB Ethernet adapter. If you do this, best to go into BIOS Setup and disable this PHY so it isn't enumerated at all.
I know it's old but the computer is running just fine other than this issue. Apparently, it is a known problem and Intel has published a fix but the link to it is broken. NVM Update Utility for Intel® 82579V Gigabit Ethernet PHY Network Connection.
n_scott_pearson
Yea, Intel cleared all of the content for discontinued products off their website. Perhaps someone can get this via the wayback machine (Al, are you listening?).
AlHill
The article was first captured on 29 OCT 2015:
https://web.archive.org/web/20151029023344/https://downloadcenter.intel.com/download/22026
I have attached the Zip file:
Doc
n_scott_pearson
Thanks Al, I have *got* to learn how to use that site!
Caguicla_Intel
Hello User15878524073827304901,
Good day!
We'd like to check if you were able to update the firmware using the provided file above? In case you have additional questions and clarifications, please let us know so we can assist you further.
We look forward to your reply.
Should there be no response from you, we will follow up after 3 business days.
Crisselle C
Intel® Customer Support
Yes, I was able to update the firmware using the file that you provided in your email to me. My problem is now resolved. Thank you and the others that replied.
Caguicla_Intel
You're welcome. We are glad to hear the the issue was now resolved.
With this, please be informed that we will now close this request. Thank you for your time and cooperation throughout the process. Should you have any other concerns or assistance needed in the future, just feel free to post a new question.
May you have a lovely day!
Crisselle C
