HI!
I have the adapter X710 DA2 and X710 DA4, using LR SFP+ Module (Intel DUAL RATE 1G/10G SFP+ LR (bailed) FTLX1471D3BCV-IT),
does not UP ethernet link in mode 1G between devices.
Also can not dump the settings to the EEPROM of the SFP module in response to receiving
Cannot get module EEPROM information: Operation not supported
When you try to off auto-negotiation or change speed to 1000 also have
Cannot get current device settings: No such device
not setting speed
not setting duplex
not setting autoneg
below information about
driver information:
driver: i40e
version: 1.5.16
firmware-version: 4.42 0x80001921 0.0.0
bus-info: 0000:0a:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
interface status :
p2p1 Link encap:Ethernet HWaddr 3c:fd:fe:9d:40:38
inet addr:xxx.xxx.xxx.xxx Bcast:xxx.xxx.xxx.xxx Mask:255.255.255.0
inet6 addr: fe80::3efd:feff:fe9d:4038/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:4358 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:728252 (728.2 KB)
Settings for p2p1:
Supported ports: [ FIBRE ]
Supported link modes: 1000baseT/Full
10000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: No
Advertised link modes: 10000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: No
Speed: 10000Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Transceiver: external
Auto-negotiation: off
Supports Wake-on: d
Wake-on: d
Current message level: 0x0000000f (15)
drv probe link timer
Link detected: yes
Is it possible the work of these SFP+ when using the adapter X710 DA2 in 1GB mode?
If so, why do I have these conflicts with modules?
- Tags:
- Modules
Hi Konstantin_1975,
I've noticed you've also posted similar question in this link - https://communities.intel.com/thread/105405 https://communities.intel.com/thread/105405
please continue the issue investigation on that thread.
regards,
Vince
Yes, the ticket # 105405 is created as deeper in terms of information.
Continued research in this ticket
Guys, was there any resolution in that ticket? We have exactly same problem: intel X710-DA2 network controller with Intel's SFP+ module (Intel® Ethernet SFP+ SR Optics E10GSFPSR - Dual Rate 10GBASE-SR/1000BASE-SX) is not working. No link up and attempts to get module information ends with "Operation not supported".
~ # ethtool -i enp4s0f1
driver: i40e
version: 1.5.25
firmware-version: 5.04 0x800024c6 0.0.0
expansion-rom-version:
bus-info: 0000:04:00.1
supports-test: yes
~ # ethtool -m enp4s0f1
Cannot get module EEPROM information: : Operation not supported
We've also updated NVM to the latest version, and we use recent driver (1.5.25).
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
