Ethernet Products
5667 Discussions
BIOS error "Major - 146 - PCI out of resource" - when multiple gigabit ethernet card is inserted(more than 3 card)
Employé
3 952 Visites
Test Setup Environment:
  • canoe pass system
  • BIOS version - SE5C6000.86b.01.02.006 and SE5C600.86b.99.99.x040
  • platform ID - S2600CP
Tried to boot the system with 4 10 gigabit ethernet card .BIOS erro is pop up with "Major -146 PCI out of resource".with 3 cards there no issue found and it is able to boot the system.
Thanks in advance.
0 Compliments
8 Réponses
Patrick_K_Intel1
Employé
2 776 Visites
Thanx for posting to the community.
I have a couple of questions that may help figure out the problem.
What are the 10GbE cards you are using?
Is SR-IOV enabled?
Does it make a different which slot the last card is in?
thanx,
Patrick
0 Compliments
Mark_H_Intel
Employé
2 776 Visites
You might be running out of IO address space. If you do not need to use network boot you could disable IO Map Mode. See Doug Boom's blog, /community/wired/blog/2010/07/30/io-util-tool IO Util Tool for details. The utility is included in the Administrative Tools webpack available for download at http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=4237 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=4237.
Mark H
0 Compliments
Employé
2 776 Visites
Thanks !
How to diable the IO map mode is it in BIOS(which option)?
SRIOV is diabdled in the BIOS.Using fedora 14 setup. Some time i am getting the error "NMI recieved system halted" on boot up.
0 Compliments
Douglas_B_Intel
Employé
2 776 Visites
Patrick has some great questions and I have a few of my own. Is IO mapped resourses enabled on each of the cards? You might be running out of IO resourses. Use can IOUtil (on the media at APPS\TOOLS\IOUtil) and turn it off if you aren't using it. What would be using it are the Option ROMs, another thing that could be consuming BIOS resources. If you aren't using PXE/iSCSI boot or FCoE Boot, you can turn off the Option ROMs using BootUtil (located at APPS\BootUtil). The readmes in each directory provide the usage and install details.
Hopefully between Patrick's advice and mine can get going. Mark the question as answered please if it helps, or post more data if it doesn't. Good luck!
0 Compliments
Daniel_O_Intel
Employé
2 776 Visites
You cannot manually disable resources, but you can disable the unused Boot ROMs like Douglas suggested. That will free up additional PCI resources.
0 Compliments
Employé
2 776 Visites
I am linux fedora 14. I downloaded the IO util .exe for dos i think so.....
How can i do for the linux system ?
0 Compliments
Employé
2 776 Visites
Dear vaishali,
Greetings!!!
Change the bios settings of Memory Mapping.
Go to BIOS => Advanced => PCI Configuration =>
Maximize Memory below 4GB Disabled
Memory Mapped I/O above 4 GB Enabled
Memory Mapped I/O Size
I hope this will solve your issue.
with thanks and regards,
C.Raja
0 Compliments
Employé
2 776 Visites
BIOS setup has an option for MMIO over 4GB = Enabled,i will accept this will have an impact to our gigabit ethernet device. Since Gigabit ethernet PCIe endpoint device's MMIO is configured as Prefetchable address space in the configuration space for all the functions.
I believe If the PCI device is configured as Non-prefetchable then there will be no effect when we setup MMIO over 4GB = enabled.
i think i am not wrong ,somewhere in the PCIe spec i have seen the Implementation note for Non-pre-fetch address space restriction.
And even gigabit ethernet will require less memory region only, even with SRIO-V feature enabled.
Gigabit Ethernet card Memory allocations
SRIOV
PF0
PF1
PF0VFs
PF1 VFs
Total Memory
Enabled
512K + 16K = 528K
512K + 16K = 528K
32K * 64 Vfs = 2048K
32K *64 Vfs = 2048K
5152K
Memory allocation will be of 5152 K (Per card memory requirement) * 5(max 5 cards) = 25760K.
My hunch is that pnp bridge configuration or the PCI bridge address range allocation for the endpoint device in the BIOS(By increasing range) can slove this issue even if the memory space for the PCIe endpoint device is larger in MB size.
0 Compliments
Répondre
