Ethernet Products
5658 Discussions
Error on latest e1000e Linux driver for ubuntu22.04
Vivian996
To install version 3.8.4 of the e1000e Linux* Intel® Network Adapter Driver for Intel® Gigabit Network Connections for PCI Express*. Use `sudo make install` in e1000e-3.8.4/src, below is the error log:
Vivian996_0-1679015955543.pngVivian996_1-1679016001324.pngVivian996_2-1679016029180.png
If want to know more details, the full log is here:
song@ubuntu-2204:~/Downloads/e1000e-3.8.4/src$ sudo make install
[sudo] password for song:
*** The target kernel has CONFIG_MODULE_SIG_ALL enabled, but
*** the signing key cannot be found. Module signing has been
*** disabled for this build.
make[1]: Entering directory '/usr/src/linux-headers-5.19.0-35-generic'
  CC [M]  /home/song/Downloads/e1000e-3.8.4/src/netdev.o
In file included from /home/song/Downloads/e1000e-3.8.4/src/e1000.h:14,
                 from /home/song/Downloads/e1000e-3.8.4/src/netdev.c:30:
/home/song/Downloads/e1000e-3.8.4/src/kcompat.h: In function ‘__kc_xdp_umem_get_data’:
/home/song/Downloads/e1000e-3.8.4/src/kcompat.h:6696:45: error: ‘*(umem->pgs + (sizetype)(((addr) >> 12) * 8))’ is a pointer; did you mean to use ‘->’?
 6696 |         return umem->pgs[addr >> PAGE_SHIFT].addr + (addr & (PAGE_SIZE - 1));
/home/song/Downloads/e1000e-3.8.4/src/kcompat.h: In function ‘__kc_xdp_umem_get_dma’:
/home/song/Downloads/e1000e-3.8.4/src/kcompat.h:6704:45: error: ‘*(umem->pgs + (sizetype)(((addr) >> 12) * 8))’ is a pointer; did you mean to use ‘->’?
 6704 |         return umem->pgs[addr >> PAGE_SHIFT].dma + (addr & (PAGE_SIZE - 1));
/home/song/Downloads/e1000e-3.8.4/src/netdev.c: In function ‘e1000_configure_rx’:
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:3714:41: error: passing argument 1 of ‘freq_qos_update_request’ from incompatible pointer type [-Werror=incompatible-pointer-types]
 3714 |                 freq_qos_update_request(&adapter->pm_qos_req, lat);
      |                                         struct pm_qos_request *
In file included from /home/song/Downloads/e1000e-3.8.4/src/kcompat.h:2737,
./include/linux/pm_qos.h:307:54: note: expected ‘struct freq_qos_request *’ but argument is of type ‘struct pm_qos_request *’
  307 | int freq_qos_update_request(struct freq_qos_request *req, s32 new_value);
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:3723:17: error: implicit declaration of function ‘pm_qos_update_request’; did you mean ‘freq_qos_update_request’? [-Werror=implicit-function-declaration]
 3723 |                 pm_qos_update_request(&adapter->pm_qos_req,
/home/song/Downloads/e1000e-3.8.4/src/netdev.c: In function ‘e1000e_open’:
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:5189:52: error: ‘PM_QOS_CPU_DMA_LATENCY’ undeclared (first use in this function)
 5189 |         freq_qos_add_request(&adapter->pm_qos_req, PM_QOS_CPU_DMA_LATENCY,
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:5189:52: note: each undeclared identifier is reported only once for each function it appears in
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:5189:30: error: passing argument 1 of ‘freq_qos_add_request’ from incompatible pointer type [-Werror=incompatible-pointer-types]
./include/linux/pm_qos.h:304:51: note: expected ‘struct freq_constraints *’ but argument is of type ‘struct pm_qos_request *’
  304 | int freq_qos_add_request(struct freq_constraints *qos,
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:5189:9: error: too few arguments to function ‘freq_qos_add_request’
./include/linux/pm_qos.h:304:5: note: declared here
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:5243:33: error: passing argument 1 of ‘freq_qos_remove_request’ from incompatible pointer type [-Werror=incompatible-pointer-types]
 5243 |         freq_qos_remove_request(&adapter->pm_qos_req);
./include/linux/pm_qos.h:308:54: note: expected ‘struct freq_qos_request *’ but argument is of type ‘struct pm_qos_request *’
  308 | int freq_qos_remove_request(struct freq_qos_request *req);
/home/song/Downloads/e1000e-3.8.4/src/netdev.c: In function ‘e1000e_close’:
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:5330:9: error: implicit declaration of function ‘pm_qos_remove_request’; did you mean ‘freq_qos_remove_request’? [-Werror=implicit-function-declaration]
 5330 |         pm_qos_remove_request(&adapter->pm_qos_req);
In file included from ./include/linux/string.h:253,
                 from ./include/linux/bitmap.h:11,
                 from ./include/linux/cpumask.h:12,
                 from ./arch/x86/include/asm/cpumask.h:5,
                 from ./arch/x86/include/asm/msr.h:11,
                 from ./arch/x86/include/asm/processor.h:22,
                 from ./arch/x86/include/asm/timex.h:5,
                 from ./include/linux/timex.h:67,
                 from ./include/linux/time32.h:13,
                 from ./include/linux/time.h:60,
                 from ./include/linux/stat.h:19,
                 from ./include/linux/module.h:13,
                 from /home/song/Downloads/e1000e-3.8.4/src/netdev.c:6:
/home/song/Downloads/e1000e-3.8.4/src/netdev.c: In function ‘e1000_set_mac’:
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:5359:22: warning: passing argument 1 of ‘__builtin_memcpy’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
 5359 |         memcpy(netdev->dev_addr, addr->sa_data, netdev->addr_len);
./include/linux/fortify-string.h:379:27: note: in definition of macro ‘__fortify_memcpy_chk’
  379 |         __underlying_##op(p, q, __fortify_size);                        \
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:5359:9: note: in expansion of macro ‘memcpy’
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:5359:22: note: expected ‘void *’ but argument is of type ‘const unsigned char *’
/home/song/Downloads/e1000e-3.8.4/src/netdev.c: In function ‘e1000_probe’:
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:8619:22: warning: passing argument 1 of ‘__builtin_memcpy’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
 8619 |         memcpy(netdev->dev_addr, adapter->hw.mac.addr, netdev->addr_len);
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:8619:9: note: in expansion of macro ‘memcpy’
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:8619:22: note: expected ‘void *’ but argument is of type ‘const unsigned char *’
/home/song/Downloads/e1000e-3.8.4/src/netdev.c: In function ‘e1000e_set_interrupt_capability’:
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:2315:35: warning: this statement may fall through [-Wimplicit-fallthrough=]
 2315 |                 adapter->int_mode = E1000E_INT_MODE_MSI;
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:2317:9: note: here
 2317 |         case E1000E_INT_MODE_MSI:
/home/song/Downloads/e1000e-3.8.4/src/netdev.c: In function ‘e1000e_reset’:
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:4543:20: warning: this statement may fall through [-Wimplicit-fallthrough=]
 4543 |                 if (adapter->netdev->mtu > ETH_DATA_LEN) {
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:4551:9: note: here
 4551 |         default:
/home/song/Downloads/e1000e-3.8.4/src/netdev.c: In function ‘e1000_setup_rctl’:
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:3566:32: warning: this statement may fall through [-Wimplicit-fallthrough=]
 3566 |                         psrctl |= PAGE_SIZE << E1000_PSRCTL_BSIZE3_SHIFT;
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:3568:17: note: here
 3568 |                 case 2:
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:3569:32: warning: this statement may fall through [-Wimplicit-fallthrough=]
 3569 |                         psrctl |= PAGE_SIZE << E1000_PSRCTL_BSIZE2_SHIFT;
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:3571:17: note: here
 3571 |                 case 1:
/home/song/Downloads/e1000e-3.8.4/src/netdev.c: In function ‘__e1000e_disable_aspm’:
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:7554:31: warning: this statement may fall through [-Wimplicit-fallthrough=]
 7554 |                 aspm_dis_mask |= PCI_EXP_LNKCTL_ASPM_L0S;
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:7556:9: note: here
 7556 |         case PCIE_LINK_STATE_L1:
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:257: /home/song/Downloads/e1000e-3.8.4/src/netdev.o] Error 1
make[1]: *** [Makefile:1850: /home/song/Downloads/e1000e-3.8.4/src] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-5.19.0-35-generic'
make: *** [Makefile:73: default] Error 2
/home/song/Downloads/e1000e-3.8.4/src/kcompat.h:6696:22: error: ‘struct xdp_umem’ has no member named ‘pages’; did you mean ‘pgs’?
 6696 |         return umem->pages[addr >> PAGE_SHIFT].addr + (addr & (PAGE_SIZE - 1));
      |                      pgs
/home/song/Downloads/e1000e-3.8.4/src/kcompat.h:6704:22: error: ‘struct xdp_umem’ has no member named ‘pages’; did you mean ‘pgs’?
 6704 |         return umem->pages[addr >> PAGE_SHIFT].dma + (addr & (PAGE_SIZE - 1));
      |                      pgs
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:3714:17: error: implicit declaration of function ‘pm_qos_update_request’; did you mean ‘freq_qos_update_request’? [-Werror=implicit-function-declaration]
 3714 |                 pm_qos_update_request(&adapter->pm_qos_req, lat);
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:5189:9: error: implicit declaration of function ‘pm_qos_add_request’; did you mean ‘freq_qos_add_request’? [-Werror=implicit-function-declaration]
 5189 |         pm_qos_add_request(&adapter->pm_qos_req, PM_QOS_CPU_DMA_LATENCY,
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:5189:50: error: ‘PM_QOS_CPU_DMA_LATENCY’ undeclared (first use in this function)
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:5189:50: note: each undeclared identifier is reported only once for each function it appears in
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:5243:9: error: implicit declaration of function ‘pm_qos_remove_request’; did you mean ‘freq_qos_remove_request’? [-Werror=implicit-function-declaration]
 5243 |         pm_qos_remove_request(&adapter->pm_qos_req);
/home/song/Downloads/e1000e-3.8.4/src/netdev.c: In function ‘e1000_io_slot_reset’:
/home/song/Downloads/e1000e-3.8.4/src/netdev.c:8100:9: error: implicit declaration of function ‘pci_cleanup_aer_uncorrect_error_status’ [-Werror=implicit-function-declaration]
 8100 |         pci_cleanup_aer_uncorrect_error_status(pdev);
 4551 |         default:
 3568 |                 case 2:
 3571 |                 case 1:
Fariz_Intel
Hi Vivian996,
We apologize for any inconvenience caused by this issue. We would be grateful if you could give some information as per below:
  • What is you NIC model e.g. Intel I219/I225?
  • What is your Ubuntu kernel version?
  • If you are using Linux Kernel 5.19, have you test with different version e.g. Linux Kernel 6 or lower?
Fariz_Intel
Fariz_Intel
Hi Vivian996,
If you have additional questions or clarifications, feel free to let us know.
Fariz_Intel
Fariz_Intel
Hi Vivian996,
Since we have not seen an update, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Fariz_Intel
