The ethernet adapter comes with my motherboard ROG STRIX B550-A GAMING.
I can neither uncheck "Allow device to wake up the PC" nor check "Allow only Magic Packets" on device settings in Device Manager.
I tried updating drivers, both from intel page and from my motherboard's support page.
I'm sure it's the ethernet adapter cause disabling it via the control panel solves the issue.
I really can't get why the options in Device Manager are greyed out.
Thanks for your time
I have the same motherboard and had the same issue
go to device manager
network adapters
right click on the intel ethernet controller i225v -> properties
click advanced tab and scroll down
the last 3 should be:
wake on magic packet
wake on magic packet on s5
wake on pattern match
click on each one and set value to disabled
make sure to click apply and ok
your all set
Hi Cigo,
Please allow us some time to review the details and we will get back with an update shortly.
Thanks & Regards,
Poojitha.N
Hi Cigo,
Good day!
Could you please Reseat the Ethernet card and Reboot the system after reseat.
kindly update the status on the same.
Thank you
Poojitha.N
Can you be a bit more specific with "reset your device"? What am I supposed to do? Do you mean "Roll Back drivers" or "Uninstall device" from device settings in Windows device manager?
Hello Cigo,
Greetings for the day!
We are following up to find out if you were able to find the information we provided. Please reply to confirm, so we can continue helping on a resolution. Looking forward to receiving your reply.
Poojitha
Hi Cigo,
Could you please confirm is Ethernet card embedded on your motherboard?,
Thanks & Regards,
Poojitha
Hi @Cigo
Did you check the possibility of disabling WOL function using BIOS settings? I'm not familiar with the BIOS on your board, but you may try to check the APM Configuration and disable the WOL there.
Leon
I think it has to be on now, and I will check if it fixes the problem, but I think it will for sure.
The point is I might decide to turn on WOL eventually and I want only magic packets to turn the computer on, which is what is not happening now and it's the source of my problem.
I will see if the options in the device manager will be unlocked when I disable WOL from bios.
I checked, it was already disabled. Trying to enable the Power on by WOL didn't change anything.
@Cigo Many times, after such a change, a physical power down and back up is required.
Hi Cigo,
It seems like there might be an issue with the system as well, so I would recommend reaching out to ASUS. They can provide support and guidance in diagnosing and resolving any problems with their products.
Please feel free to reach out if you require any additional information or assistance.
Thank you!
Poojitha
Hi Cigo,
We are following up to find out if you were able to find the information we provided . It seems like there might be an issue with the system as well, so I would recommend reaching out to ASUS. They can provide support and guidance in diagnosing and resolving any problems with their products.
Thank you!
Poojitha
Hi Cigo,
Thank you!
Poojitha
network adapters
your all set
I got this exact same answer from Asus forum and it solved my problem. But thanks anyways!
