Ethernet Products
5821 Discussions
How to fix corrupted Ethernet NVM, which results in non-functioning GbE interface
MDuba3
Server board S1200BTL reports on POST that the NIC NVM is corrupt, and so the GbE interface does not work. This occurred after a reboot, with no change in configuration. Subsequently updating the firmware package made no difference. I tried disabling and re-enablign the NIC and the NIC ROM in BIOS, to no effect. A search for a suitable Ethernet flash package turned up zero. What else can I try?
Mike_Intel
Hello MDuba3,
Since you already tried updating the NIC's NVM, you may try to update the firmware of the board.
Please open the link below for the steps on how to update the firmware of the board.
https://www.intel.com/content/www/us/en/support/articles/000032841/server-products.html
If you have questions, please let us know.
Michael L.
Intel Customer Support Technicians
A Contingent Worker at Intel
MDuba3
Hi
Thanks for the response. However, the opposite is actually the case: I've updated the board's formware but not the NIC. If you can post a link to the right NIC firmware (I've looked and can't find) that would be helpful. Many thanks.
Mike_Intel
Hello MDuba3,
Thank you for the update. Let me further check this issue and get back to you.
Please give me 2 to 3 workings days to work on this issue and provide an update.
Michael L.
Mike_Intel
Hello MDuba3,
Upon further checking, there is no NVM available for your on-board NIC.
And since the NIC is on-board, it is also best if you will try to ask our server department if there is an available NVM. And also, let me just add that since you are already done updating the firmware of the board and you are still having the same issue. There is a possibility that the on-board NIC is already faulty.
Michael L.
MDuba3
Hi Mike
Thank you for your work on this.
I shall post a question on this in the server section of this support forum.
