Ethernet Products
5667 Discussions
I cannot install OFDX-4.17-1 in Ubuntu 22.04 environment [E810]
zhaojin
I want to use the RDMA function of the intel E810 network card. The irdma driver can be installed normally, but there is a problem when installing OFED-4.17-1 according to the intel irdma README.
I do the following:
1. "cd OFED-4.17-1"
2. "./install.pl"
3. select option2 "Install OFED Software"
4. then select option2 "All packages"
But, it shows "0 packages selected". Then "Exiting" , and install failed.
Do you konw why?
IntelSupport
Community Manager
Thank you for posting on the Intel communities.
Please give us 2-3 business day to check on this and get back to you.
In the meantime please check if you have the updated driver for Intel® Network Adapter Driver for E810 Series Devices under Linux* - Kindly check the readme files on the site provided above if it helps.
You are advised to go thru below link as well:
https://openfabrics.org/downloads/OFED/release_notes/OFED_4.17-1-release_notes
Can you please confirm the Intel E810 specifications that you are using.
Kindly provide us with an update as well once you have done above steps.
Thank you.
Hayat
Intel Customer Support
IntelSupport
Community Manager
Hello zhaojin,
Regarding your thread, we are following up to find out if you were able to complete the actions, we previously recommended.
Kindly check on this as well - https://downloadmirror.intel.com/29751/eng/readme_irdma_1.6.28.txt
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Thank you.
Hayat
Intel® Customer Support
IntelSupport
Community Manager
Hi zhaojin,
Since we haven't received any response from your end.
Thus, we will proceed to close the thread from our end.
If you have any additional queries, kindly submit a new thread as this thread will no longer be monitored.
Thank you.
Hayat
