Ethernet Products
5655 Discussions
I210 Teaming after Windows 10 April 2018 Update
n_
I had a pair of I210 NICs (a dual-NIC motherboard) teamed via Static Link Aggregation and all was working fine until today when Windows 10 x64 decided to apply the April 2018 cumulative update. The page providing the respective drivers with ANS support (https://downloadcenter.intel.com/download/25016/Intel-Network-Adapter-Driver-for-Windows-10?product=64399 https://downloadcenter.intel.com/download/25016/Intel-Network-Adapter-Driver-for-Windows-10?product=64399) states that the latest version is 23.1 (dated 2018-02-21). Even with this latest driver, however, I can re-create the team, but it cannot be enabled. The only way to keep things in a sort of working state is to disable one of the NICs as well as the virtual team interface and keep only the other NIC active (i.e., not an ideal scenario).
Is there any chance that a new version of the driver will be available soon?
nvx
Hi MichaelWolff and all,
Understand some of you are encountering issue when configured VLAN using new PROSet software 23.2, please try the following steps:
1. Make sure to fully remove any Teams | VLANS
2. Uninstall previous drivers/PROSet for the network adapter.
3. Install 23.2 SW
4. Reboot System
5. Teaming and VLAN (tabs) should be available in Adapter Properties as part of ANS
Sharon T
SAyod
I thought that died years ago. You're using Microsoft's driver, so I would guess intel doesn't support it any more. I thought it https://heraldsheets.com/ https://www.eaglesnewsmedia.com/ died with Windows 8 or something. ht
SWund1
1. Ver 23.1
2. After the 23.2 release
3. I am connect to the internet using the teams
ssean3
I was able to install the driver and create a team with no issues, however, for some reason the team only shows 1Gbps when it should be 2Gbps.
Edited screenshot.
ŁTuro
Show Network Card Driver Details not Graphic Card, please
I am curious of drivers version though.
ssean3
edited my screenshot. My apologies.
GCari
I do not find formatting as an option for this
JAase
So ... remove teams/virtual nics (vlans). Uninstall driver (include checkbox for delete driver), reboot, install new driver, upgrade to 1803, set up teams/vnics/vlans .... should work?
AGuer8
The new 23.2 works probably only until the next windows update. Intel needs to stay on top of these things.
PHo8
Works for me. I manually updated my drivers and then ran the autorun in the zip file to install ANS and I am able to create a team showing 2.0 Gbps. Running Win 10 Pro 1803. Using the two onboard Intel network ports on the GA-H270N WiFi motherboard.
JAase
You who report that it doesn't work:
Can you please double check that you actually have the right driver installed via device manager? And have you tried to remove the old driver first?
AGuer8
I didn't uninstall the old software. I installed the new software then deleted the interfaces from device manager and rebooted. Everything came up fine after that.
MWolf8
Intel X550-T2
i used the 23.2 version from the x550-t2 driver-downloadpage but still driver dated to 17.10.2017 and version 4.1.74.0 tried to update manual but can´t find any newer driver in the package.
MM69
The new driver 23.2 works for my X550-T2 an Windows 10 1803.
Just try it.
ZKłos
New 23.2 driver was just released, it claims teaming support for RS4/1803 Windows build.
GCari
If I look for the latest driver for my I210 device in support, it still comes out as the last version 23.1
ARosb
GCari
I've already tried it and it does not work for me. My comment comes because it looks more like a beta than something tested, because it does not appear on the official download.
MM69
You have to download the complete driver package for all OS. Only this is in Version 23.2
https://downloadcenter.intel.com/de/product/64399 Downloads für Intel® I210-Ethernet-Controller
ARosb
GCari
The first thing that happens to me with that version is this:
Which is something that with a final version would not happen.
When creating a team I get the following error:
Clearly there is a problem. And although the equipment generates it, as with version 23.1, it is impossible to activate the adapter.
A question to those who have worked. The version of drivers that installs you is this ?:
Thanks and best regards
