Ethernet Products
5720 Discussions
I210 driver issue in Linux
I am using Ubuntu 16.04 LTS operating system, with igb-5.3.5.4 driver. I have two I210 Ics on board.
I have programmed iNVM in both devices and
"lspci" is identifying the devices and lsmod also showing igb module with no user for it(i.e. 0)
"lshw" is also showing devices with network -UNCLAIMED.
How to bind this igb driver to i210 controllers?
The board is also having I217 controller with e1000e driver and it is working fine.
Please help me in resolving this issue
HI Abhik1,
Thank you for the post. The Intel I210 Ethernet controller is for single port Gigabit LOM design, it needs to be teamed with another network adapter.
rgds,
wb
HI Abhik1,
Please feel free to update me if you need clarification.
thanks,
wb
Hi Abhik1,
You can also post your inquiry at http://embedded.communities.intel.com/ embedded.communities.intel.com for them to further assist you.
rgds,
wb
MBufa
wb,
I have a similar application, but I don't understand exactly what you're saying here. Are you saying that the I210 can't be simply attached to a PCIe bus and used as an Ethernet adapter?
mdbetn
Hi Mdbetn,
This is an onboard NIC so you can post your inquiry to the embedded support group for them to better assist you.
Rgds,
wb
