Ethernet Products
5719 Discussions
Problem with Intel Driver Update Utility giving me repeatedly the same driver version!
@Having a problem with Intel Driver Update Utility giving me repeatedly the same driver version like "Intel Network Adapter Driver V 12.15.23.7" than I install it after when ready I restart my PC. When I see the Windows screen and I repeat to open application again with Intel Update Driver Utility it will give me again the same driver version "Intel Network Adapter Driver V 12.15.23.7" and again I will repeat and hangs again in the Utility!
I followed the log file directory and send you a screenshot report of it so maybe it will help you!
Hello Mikant,
I will be more than glad to assist you with your concern.
For an extensive research, I would like to confirm the model of your PC? And the model of your Processor?
As soon as you reply I will continue with the research in order to assist you.
Angie
Hello Angie,
I have ASUS Z97 Maximus VII Hero Motherboard 1150 CPU socket and Intel® Core™ i7-4790K Processor (8M Cache, up to 4.40 GHz). Thanks for your help.
Michael
Hello Mikant,
Thanks for your reply.
I am still investigating your issue. In the meantime, could you please try to uninstall and install the application and run it:
http://www.intel.com/content/www/us/en/support/detect.html Intel® Driver Update Utility
Please let me know the outcome, hope I can hear from you soon.
Angie
Hello Mikant,
I would like to know if the information provided to you was able to solve your concern?
In case if you need further assistance do not hesitate to reply back.
I am looking forward to hearing from you.
Angie.
Allan_J_Intel1
Hello Alan
I have tried to uninstall and reinstall your latest Intel Driver Update Utility new version 2.6.2.4 but it's still the same problem update.
Michael
Allan_J_Intel1
Let's check if you already have the latest version installed. Please run the following utility and attach the results.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility
In order to attach files, make sure you select the "Advanced Editor" option in the top right of your reply window. You will then be presented with an attach file dialogue at the bottom of the reply.
Allan.
Hello Mikant,
Please let me know if the previous steps suggested, were able to help you with your matter?
If the issue persists, please reply with the information that was requested in the previous post.
Angie
