Ethernet Products
5862 Discussions
Intel 82579LM Gigabit Network Connection
JSpit2
Windows XP missing "Microsoft TCP/IP version 4"
How do I get that back/??
It used to be there - but, it disappeared - just noticed that..
n_scott_pearson
Um, install a supported O/S?
JSpit2
Mike_Intel
Hello JSpit2,
Please try to re-installing the TCP/IP protocol, just follow the steps below and if that did not work you can try re-install the Operating system.
1) Go the My Network Places and right click to choose Property
2) Select Local Area connection, right click to choose property
3) Click on the Install button to select the protocol from the list. click Add then Have Disk to search for the protocol to re-install
By the way, Windows XP is a legacy operating system and support has been ended and since this is a Microsoft Windows XP configuration, it would be best still if you try to contact and check this issue with Microsoft.
If you have questions, please let us know.
Michael L.
Intel Customer Support Technicians
A Contingent Worker at Intel
Mike_Intel
Hello JSpit2,
I just want to check if you already tried our last recommendations.
Michael L.
JSpit2
I never really had it on Windows XP - so, I guess I am not missing anything.. Thanks for checking..
Mike_Intel
Hello JSpit2,
Have you tried our 3 steps recommendations above? What is the outcome?
If the steps that we provided did not worked, it is best if you try to contact Microsoft regarding the issue.
Michael L.
Mike_Intel
Hello JSpit2,
Just want to check if you are still having the issue.
Michael L.
Mike_Intel
Hello JSpit2,
Sending another follow up to check how is the system right now.
Michael L.
JSpit2
I am guessing I don't have a problem with not being able to see Microsoft TCP/IP Version 4 in my Windows XP OS. The version of your software that came with my Dell 7010 Computer I presume is not compatible with The XP OS... My Windows 7 on the same Computer shows the TCP/IP Version 4 just fine along with the Version 6.. I get everything over the internet just fine, so, I'm not going to worry about it anymore..
Mike_Intel
Hello JSpit2,
Thank you for the reply. Aside from this, do you need any assistance from us?
Michael L.
JSpit2
Mike,
OK, in doing some research, it seems I need the following software for Windows XP:
Intel82579LM Gigabit Network Connection Internet Protocol Version 4(TCP/IPv4) Driver
Hopefully you can send me that file so I can get my IPv4 working using YOUR Internet hardware and software..
Thank You..
Joe
Mike_Intel
Hello JSpit2,
If you are referring to the Windows XP driver for 82579LM, you may download this driver to the link below:
https://downloadcenter.intel.com/download/18717/Network-Adapter-Drivers-for-Windows-XP-Final-Release?product=47620
As stated on the link, this is the final release as Windows XP is a legacy operating system.
Michael L.
JSpit2
Hey, thanks - I'll give that a try and see what happens!!
Mike_Intel
Hello JSpit2,
Thank you, I will wait for your update on this.
Michael L.
Mike_Intel
Hello JSpit2,
To avoid confusion, can we close this thread and continue our discussion on this thread below?
https://forums.intel.com/s/question/0D50P00004PQx7mSAD/ok-in-doing-some-research-it-seems-i-need-the-following-software-for-windows-xp?language=en_US
Michael L.
JSpit2
I did close this yesterday as you had asked me to - but, I guess it showed up again. I think your website is either messed up, or because I am an old guy I can’t fathom whats going on.. I will go to it and close it again... Thanks for trying to help me out... I presume you are getting these e,ail messages, if so, please respond so I will know you are. Joe
