Ethernet Products
5666 ディスカッション
Intel Driver & Support Assistant software install fails
DaveM1
初心者
3,115件の閲覧回数
This is the first time I have posted a query here. I have no idea what Board I should post to.
The Intel Driver and Support Assistant tells me I have an update available for my Network Adapter, so I asked it to install it (see attachment 1). The install process tells me that "No Network Connections found" and fails. I tried it a number of times after restarting my desktop (see attachment 2) but no go.
Is there a solution to fix this or should I just ignore this update?
Thanks in advance.
ラベル(1)
0 件の賞賛
9 返答(返信)
Monique_Intel
モデレーター
3,057件の閲覧回数
@DaveM1  I am the Project Manager for IDSA. Please provide your IDSA log files (zipped folders from C:/ProgramData/Intel/DSA so I can have our developers investigate. You can just zip the 'Data' & 'Logs' folders so the zip file stays below the 23MB limit to attach here.
Thank you for your help,
Monique with Intel Corporation
DaveM1
初心者
3,009件の閲覧回数
Zipped files ad requested.
Thanks!
Rich77
ビギナー
2,977件の閲覧回数
I am having the same problem. Can you please help.  Attached are the files you previously requested.
Monique_Intel
モデレーター
2,854件の閲覧回数
Thanks for your patience. The IDSA team is working on a fix for the logic for this.  The latest network driver release version for Window 10 and Windows 11 is driver version 14.0.5.0.
Monique_Intel
モデレーター
2,612件の閲覧回数
@DaveM1 @Rich77  Our team has updated the necessary detection metadata for IDSA to function correctly for this download. If you could try running IDSA and choose the "Refresh Results" on the left-hand IDSA menu, please let us know if the correct version is offered and installs without issue.
Thank you for your patience while we fixed this.
DaveM1
初心者
2,595件の閲覧回数
Monique,
I am now getting:
No supported driver or software updates are available for your system.
Is there supposed to be an update for my system? I hope so because for the last few weeks every time I log in I have to disable and re-enable my wireless network adapter to get it to work. I don't know if this problem is related to this issue.
Rich77
ビギナー
2,509件の閲覧回数
I too, get the "No supported driver or software updates are available for your system."
Does this mean that there are no updates for my system?  I am curious because you earlier said that the latest driver for windows 10 is version 14.0.5.0 while I am using version 12.17.10.6.
I am attaching the data & log files.
Monique_Intel
モデレーター
2,571件の閲覧回数
@DaveM1  I would need to have my developers review your most recent IDSA logs to see if your specific system was supposed to be offered any updates and ensure the detection is working accurately. You can zip the 'Data' & 'Logs' folders together (or separately) from C:/ProgramData/Intel/DSA and attach here.
I don't believe this would be related to the wireless adapter issue you're experiencing since wireless and ethernet (wired) are different.
Thanks for your help,
DaveM1
初心者
2,485件の閲覧回数
Please find attached the Data and Log directories that you requested, in one file.
返信
