Good day!
I'm using NAT MCH module with Hub-Module XAUI x48. This Hub-Module is based upon Intel Ethernet Switch FM4000 series. The problem is that Hub-Module uplink ports doesn't support 1 Gbit Ethernet, only 10 GbE. These uplink ports are connected to switch ports 3 and 8 respectively.
I'd like to know how to enable 1 Gbit Ethernet support at switch ports 3 and 8?
And also could you, please, send me FM4000 series manual with on-chip registers contents to test the product?
I've tried to create new service request but I cann't finish it - "Please select a valid Product." error appears every time I write "Intel® Ethernet Switch FM4000 Series", "Ethernet Switch FM4000", "FM4000", "FM4224", and so on.
Miloserdin Oleg
Hi Miloserdin,
Thank you for the inquiry. You may click on this link http://www.intel.com/p/en_US/support/contactsupport Contact Support to contact the switch support for further assistance.
Hope this helps.
rgds,
wb
