Ethernet Products
5301 Discussions
Intel I210: Synchronized Output Clock on SDP Pins
I am not sure if this is the right place to post this question, if not please correct me.
I am using an Intel I210 card on my linux PC. I was trying to generate a clock output on one of the SDP pins, so I followed the section-7.8.3.3.3 in Intel-i210 data sheet.
According to Time Sync Interrupt Cause Register(TSICR) description, we can get interrupts to driver for "every output clock half-cycle on SDP pin". So I configured the registers accordingly from the "igb_avb driver" (few changes to original driver in Open-AVB).
The problem is, I am not getting those clock interrupts. Basically what I was looking for is, to get periodic interrupts from the SDP clock to igb_avb driver, to perform some tasks.
Have someone tried this before ?
Registers I configured (for CLK1 on SDP1) are:
IMS - set Time sync interrupts
TSIM - enable interrupt for Target Time1(TT1)
TSSDP - enable SDP1 and assign CLK1
TSAUXC - enable CLK1
CTRL - set SDP as output
FREQOUT - set clock half-cycle
Please let me know if any more information is required.
Hi Shiva_Kumar,
Thank you for the post. I will have to check on this inquiry.
wb
Hi Shiva_Kumar,
Good day. Can you help clarify if you are actually getting clock pulses of the pin?
Can you also provide the scope shot of the pulse? Thanks.
Rgds,
wb
Hi Shiva_Kumar,
Please feel free to provide the information.
rgds,
wb
I didn't probe the SDP pin with a scope. But I was reading the "SDP1 DATA" bit periodically in "Device Control Register - CTRL" to check if there are any pulses.
Not sure if it is the right method, but I could see the level change with period read operations. But there were no interrupts to the driver.
I am not sure if I can provide a shot on scope, but I'll try.
Shiva
Hi Shiva,
Thank you. Please feel free to provide in case you are able to capture the data.
rgds,
wb
