Ethernet Products
5354 Discussions
Intel I211 network adapter slow to connect to internet Windows 10
stanmine
Not sure the exact problem, over the last two years i haven't had this issue.
When i turn my Windows 10 workstation on each day, the computer doesn't connect to the internet right away.  It generally takes ten minutes before it establishes a connection.  I had to purchase a backup wifi adapter in case it need to connect quickly.  When i launch the ProSet configuration utility it says everything is fine, there is a connection, the cable is good, hardware is good.
Been trying many things including going into the network adapter setting and disabling the computer putting the network adapter to sleep, verifying  the advanced settings, going into my router and checking settings there, reinstalling the drivers, switching the gig switches, trying new ports, switching cables.
If someone could help me fix this, i would consider it a miracle at this point.  Thank-you
Mike_Intel
Hello stanmine,
For us to further check the issue, please provide the following details.
  1. Can you share the link where you downloaded the driver that you are using?
  2. Are you using PCIe i211 card or onboard network card?
  3. What is the model of your motherboard or system?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel Customer Support Technicians
Mike_Intel
Hello stanmine,
I just want to make a follow up on the information that I requested below:
Michael L.
Mike_Intel
Hello stanmine,
I am just sending another follow up on the information that I requested.
If you need further assistance, please post a new question.
Michael L.
