Ethernet Products
5658 Discussions
Intel(R) Ethernet Connection (11) I219-V Unable to install intel network connections software
HSM
Nouveau contributeur I
102 941 Visites
英特爾(R)以太網連接(11)I219-V無法安裝英特爾網絡連接軟件2.5.1.1
板載219-V是ASUS ROG MAXIMUS XII HERO(WI-FI)
硬件識別碼:
PCI \ VEN_8086&DEV_0D4D&SUBSYS_86721043&REV_00
PCI \ VEN_8086&DEV_0D4D&CC_020000
HSM
95 104 Visites
Intel® Ethernet Adapter Complete Driver Pack
Version: 25.6 (Latest) Date: 12/18/2020
25.6 Released : https://downloadcenter.intel.com/download/22283/Intel-Ethernet-Adapter-Complete-Driver-Pack
Glad my problem is solved , The Z490 platform is installed correctly.
Voir la solution dans l'envoi d'origine
0 Compliments
101 Réponses
AlfredoS_Intel
Modérateur
30 384 Visites
Hi HSM,
Thank you for posting in our Intel® Ethernet Communities forum.
We would like to get more context about your issue before we start assisting you.
To start, we need to get the configuration of your system. Please download an run our Intel® System Support Utility software from this link, https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-.
Please save the logs to a text file, and reply to this thread with the file attached.
Looking forward to your reply. Should we not get your reply, we will follow up with you after 3 business days.
Alfred S
Intel® Customer Support
0 Compliments
HSM
30 379 Visites
intel ssu log file Attached file.
0 Compliments
AlfredoS_Intel
Modérateur
30 364 Visites
Hi HSM,
Thank you for those logs.
We would appreciate it if you will provide us a screenshot of the actual error when you install drivers.
Looking forward to your reply. Should we not get your reply, we will follow up after 3 business days.
Alfred S
0 Compliments
HSM
30 360 Visites
Screenshot of the installation process as attached,
Last appeared without any intel interface card
0 Compliments
AlfredoS_Intel
Modérateur
30 351 Visites
Hi HSM,
Thank you for your cooperation in sharing those screenshots.
At the moment, what is the current status of the ethernet adapter in device manager?
Have you already tried installing the drivers provided by your motherboard manufacturer?
Looking forward to your reply. Should we not get your reply, we will follow up after three business days.
Alfred S
Intel Customer Support
0 Compliments
HSM
30 348 Visites
The 219-v state is the normal operation of the device.
Yes, I installed the driver from the motherboard manufacturer.
But I also tried not to install the motherboard manufacturer driver,
Change to install Intel network connection software 25.1.1,
Display No Intel interface card found.
0 Compliments
AlfredoS_Intel
Modérateur
30 337 Visites
 Hi HSM,
Thank you for your reply.
So when you installed the driver from your manufacturer, did you experience any issues?
When we checked the logs that you have provided. You actually have the latest driver for your Intel® I219-v ethernet adapter. It is either Windows updated it for you, and that is the reason why you are getting the error message or it could be already installed that is why it is giving that error message.
May we know why you are trying to update the driver? Is this to rectify some kind of issue that you are experiencing?
Please let us know. Should we not hear from you, we will check back after 3 business days.
Alfred S
0 Compliments
HSM
30 330 Visites
Manufacturer driver Not included Intel ProSet Adapter Configuration Utility .
I am used to installing the driver version provided by Intel website directly.
The driver provided by the manufacturer is not installed ,
install Intel network connection software 25.1.1 ,
Half of the installation will prompt that the driver cannot be installed. There is no Intel interface card on this computer.
However, Intel Network Connection Software 25.1.1 does install the driver, but it still lacks the "Intel ProSet Adapter Configuration Utility".
0 Compliments
AlfredoS_Intel
Modérateur
30 307 Visites
Hi HSM,
Thank you for your response.
Please allow us some time to look into this.
We will provide you with an update no later than 3 business days from now.
We may ask for additional information.
Alfred S
0 Compliments
AlfredoS_Intel
Modérateur
30 297 Visites
Hi HSM,
We are currently on the initial phases of our investigation of your concern.
While we are doing this, we found the need to know which driver version from our website, were you able to install correctly. Was it version 25.0 or earlier?
Looking forward to your answer, as we need to it for our investigation. Should we not hear from you, we will check back after 3 business days.
Alfred S
0 Compliments
HSM
30 290 Visites
I downloaded and used Intel® Ethernet Adapter Complete Driver Pack Version: 25.1.1 (Latest) Date: 6/15/2020
0 Compliments
AlfredoS_Intel
Modérateur
30 275 Visites
Hi HSM,
Thank you for the reply.
However, that is the driver version that you are having problems with and where you are getting the error message.
We are asking what was the last driver version that you installed, that is working and does not have an error message?
We look forward to your reply.
Alfred S
0 Compliments
HSM
30 272 Visites
The order of the problems I encountered during installation is "1.png" to "2.png" to "3.png"
"3.png" Although he jumped out and couldn't find any intel interface card, the driver is still installed in the computer.
0 Compliments
richard52
30 259 Visites
Hi, AlfredoS_Intel,
Have the same problem, trying to install 25.1.1, 25.0, 24.5 drivers - same error.
0 Compliments
AlfredoS_Intel
Modérateur
30 236 Visites
Hi HSM and richard52,
Thank you for the information that you have shared.
Please allow us some time to check on this matter.
We will get back to you no later than 5 business days from now.
Alfred S
0 Compliments
AlfredoS_Intel
Modérateur
30 140 Visites
Hi Hsm,
Thank you for waiting for our update.
While we were checking, these questions came into mind which will help us find a recommendation for your issue. Please answer the following questions:
1.      May we know if you have already tried using your motherboard manufacturer’s driver? If yes, are you experiencing issues with that driver and that led you to use our generic drivers?
2.      May we know why you want to use our generic drivers?
We look forward to your reply. Should we not get your reply, we will follow up after three business days.
Alfred S
0 Compliments
richard52
30 126 Visites
Hi, AlfredoS_Intel
1. I have already tried using motherboard manufacturer’s driver and it works, but manufacturer's driver doesn't support of ProADMIN tool, and doesn't support for Team and VLAN configuration.
2. I need support for Team and VLAN configuration.
0 Compliments
AlfredoS_Intel
Modérateur
30 140 Visites
Hi Hsm,
Alfred S
0 Compliments
HSM
30 138 Visites
1.The manufacturer's driver has not encountered problems in use.
2.Generally, the updated version of the manufacturer's driver is slow.
Accustomed to the direct installation of the driver provided by the Intel website.
0 Compliments
AlfredoS_Intel
Modérateur
28 432 Visites
Hi richard52,
The manufacturer driver may support VLAN. We noticed that you are using the newest Windows 10 build.
Have you tried the procedures listed here on this page, https://www.intel.com/content/www/us/en/support/articles/000035837/network-and-i-o/ethernet-products.html.
Hi HSM,
To confirm by saying slow, do you mean the ethernet speed is slow?
There maybe a reason why the intel driver does not install for you and this maybe because your motherboard manufacturer placed restrictions on your board so other drivers would not install properly.
Alfred S
0 Compliments
Répondre
