Ethernet Products
5658 Discussions
Intel(R) Ethernet Connection (11) I219-V Unable to install intel network connections software
HSM
Nouveau contributeur I
102 845 Visites
英特爾(R)以太網連接(11)I219-V無法安裝英特爾網絡連接軟件2.5.1.1
板載219-V是ASUS ROG MAXIMUS XII HERO(WI-FI)
硬件識別碼:
PCI \ VEN_8086&DEV_0D4D&SUBSYS_86721043&REV_00
PCI \ VEN_8086&DEV_0D4D&CC_020000
HSM
95 008 Visites
Intel® Ethernet Adapter Complete Driver Pack
Version: 25.6 (Latest) Date: 12/18/2020
25.6 Released : https://downloadcenter.intel.com/download/22283/Intel-Ethernet-Adapter-Complete-Driver-Pack
Glad my problem is solved , The Z490 platform is installed correctly.
Voir la solution dans l'envoi d'origine
0 Compliments
101 Réponses
AlfredoS_Intel
Modérateur
17 103 Visites
Hi Thread Members,
Thank you for waiting for your continued patience waiting for our update.
We estimate that the device IDs will be added in a future release (Likely 25.6) by the end of Q4 2020.
Specifically, we anticipate that device IDs: OD4C and 0D4D, will have support in Q4'2020 which will likely be in Release 25.6
We would like to hear your thoughts or feedback regarding this.
We will keep the thread open for 3 business days, in case you have anything else to add or ask further.
Alfred S
Intel® Customer Support
0 Compliments
azhegal
17 101 Visites
Thanks for your update, AlfredoS!
In order to have feedback, please keep this thread open till actual problem solving in release 25.6 or whichever. Personally I have doubts that issue discovered four years ago could be solved by simple adding IDs while it was not done before. This is why we've got number of DGE-560 with Realtek 8111 on board and solved the problem in our enterprise network. It cost less than $10 per PC of extra expenses but it works already today...
0 Compliments
HSM
17 041 Visites
Hi AlfredoS ,
Please keep this thread open till actual problem solving in release 25.6 , I think this is a better way.
AlfredoS_Intel
Modérateur
17 061 Visites
Hi azhegal,
Thank you for your response,
Please allow us some time to check if you request can be arranged. We hope for your understanding regarding this
We will get back to you no later than 3 business days from now.
Alfred S
0 Compliments
AlfredoS_Intel
Modérateur
17 048 Visites
Hi azhegal,
Thank you for waiting for our update.
While we were checking, these questions came in to mind which will help us find a recommendation for your issue:
We look forward to your reply. Should we not get your reply, we will follow up after three business days.
Alfred S
0 Compliments
AlfredoS_Intel
Modérateur
17 010 Visites
Hi Thread Contributors,
Thank you for your response.
No problem. You can have all the additional time that you need.
We will keep the thread open until after the new version of the driver is released.
Alfred S
0 Compliments
GCatt
Débutant
16 983 Visites
Dear AlfredoS@Intel,
Can Intel add logging information to the install so you can get specific information about why these installs are failing for you customers? Sure, asking questions and collecting system info is good, but what about some detailed logging of the install. I would make logging part of your production install with an option to switch it on so users can give you specific information about the install on their computers.
Does this sound like a good idea?
0 Compliments
Stefan_Rog
Débutant
16 870 Visites
Hello Guys,
im happy to found this thread.
i have exactly the same failure and the same motherboard.
best regards
Stefan
0 Compliments
57laurent57
Débutant
16 837 Visites
Hello, I cannot get the i219v to work on my asus tuf gaming Z490 plus wifi.
PCI\VEN_8086&DEV_0D4D&SUBSYS_86721043&REV_00
PCI\VEN_8086&DEV_0D4D&CC_020000
How do I make it work? To have my ethernet? I tried everything without success
0 Compliments
AlfredoS_Intel
Modérateur
16 826 Visites
Hi GCatt,
You do have great insights and a good idea. We need to check with our team if that is something we can explore. For now, we will consider it as a feedback.
Hi Stefan_Rog,
Since your issue is exactly the same, just like the other posters on this forum, please wait for version 25.6.
Hi 57laurent57,
If you are having the same issue with your i219v, please also wait for version 25.6.
Alfred S
0 Compliments
EffingerB
Débutant
16 800 Visites
Hi @AlfredoS_Intel,
Please count me in as another user on a Dell OptiPlex 7080 with the same issue:
Intel(R) Ethernet Connection (11) I219-LM
PCI\VEN_8086&DEV_0D4C&SUBSYS_09A41028&REV_00
PCI\VEN_8086&DEV_0D4C&CC_020000
Thank you!
0 Compliments
Nick-g
Débutant
16 759 Visites
What is your deployment eta for this patch. I just built two machines today that suffer from this issue.
I was reading through this thread from months ago....
Quite amusing that it took 5 months to accept that it was even an issue because you weren't testing with the same board...
How many hundreds of users have rma's these boards i wondered...  I did two.
Wasted hours of my life.
0 Compliments
LPong
Débutant
16 709 Visites
Hi.
I'm back on this forum, after 4y with my new Asus H470m mobo and I'm pretty disappointed that problem with VLANs is still the same.
However I used VLAN's on with my old mobo. They have been created with standard power shell procedure:
https://www.intel.com/content/www/us/en/support/articles/000035837/network-and-i-o/ethernet-products.html
Yesterday I changed my mobo and CPU but i did not made fresh Windows install. Before that I uninstalled some drivers, LAN as well. After boot I installed fresh drivers including LAN.
After that I tried to use power shell but I get this error.
I tried with Asus LAN drivers, last version of drivers in your page and also with this:
https://downloadcenter.intel.com/download/22283/Intel-Ethernet-Adapter-Complete-Driver-Pack?product=82186
But all installation packages install just drivers I don't have any temp folder where drivers are unpacked, so I can not do this part:
  1. Open the Command Prompt as an Administrator.
  2. Access the folder that is made after having unzipped the Intel® Ethernet Adapter driver package.
  3. Within the Command prompt, go to APPS > PROSETDX > Winx64.  In this folder, run the following command to install the driver along with PROSet and the Advanced Network Settings: DxSetup.exe BD=1 PROSET=1 ANS=1"
And I think that this part is responsible that I'm getting upper error.
Because I don't have folder:
C:\Program Files\Intel\Wired Networking\IntelNetCmdlets
Under "C:\Program Files\Intel\Wired Networking" there is no file/folder at all.
Can somebody help me, how to install "Pro set" to get back IntelNetCmdlet.
Thank you!
0 Compliments
HSM
95 009 Visites
0 Compliments
BrianERey
Débutant
16 569 Visites
Can confirm that issue is now fixed via Intel 25.6 driver release on my Asus Maximus XII Hero (wi-fi) as well.  PROSet and VLANs now work.  Woot!
Thanks to the OP for originally reporting and persevering.
Best,
B
0 Compliments
richard52
16 525 Visites
Thanks to Intel, problem solved with 25.6 .
0 Compliments
AlfredoS_Intel
Modérateur
15 747 Visites
Hi HSM, BrianERey richard52,
Thank you for your patience and for installing the new version of the driver.
As you already know, as posted by HSM version 25.6 is already up.
We hope that it will address the same issue of all other posters on this thread. As this thread is already marked as closed, we will continue to close this thread.
Before we lock the thread, please accept our humblest apologies for what happened on this thread. We hope for your understanding.
If you would like to give us an update or if you have further questions, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
0 Compliments
Slender
Débutant
15 509 Visites
Hello Intel, Hello Forum. I have problem with my TUF GAMING Z490-PLUS.
I have Intel® I219-V 1Gb Ethernet on my board.
The problem is that the hardware id does not match the driver written for windows 8.1. It just doesn't contain the lines of my internet card.
Everything works well on windows 10, but I need windows 8.1 due to its specifics of working with tsc.
My friend has an asus tuf plus motherboard on a z390 chipset and everything works for him.
0 Compliments
Répondre
