- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
We order an Intel X710DA2 from http://www.provantage.com/intel-x710da2~7ITEN0KM.htm Provantage and SFPs from http://www.amazon.com/Intel-E10GSFPSR-Ethernet-Optic-10GBase-SR/dp/B002OHV01K Amazon.
The NIC and accompanied SFPs work fine with full speed (10 Gbps) when connecting with other NIC Ports.
The Issue we need to ask here is when we loop the two ports of that X710DA2 together (connect the cable from port 1 to port 2 on same X710DA), the port status show "Cable Unplugged", of course the Intel IOUtil show IO not Enable:
NIC B/D/FVen-Dev MAC IO Branding string=== ======== ========= ============ === =======================================
1) 02/00/00 8086-1572 NA Intel(R) Ethernet Converged Network Adapter X710-
2) 02/00/01 8086-1572 NA Intel(R) Ethernet Controller X710 for 10GbE SFP+
Also, DPDK (1.8) testcmd shows only 1Gbps link connection between them.
# build/app/testpmd -c7 -n3 -- -i --nb-cores=2 --nb-ports=2
Port 0: 68:05:CA:30:51:B4
Configuring Port 1 (socket 0)
PMD: i40e_dev_tx_queue_setup(): Using full-featured tx path
PMD: i40e_dev_rx_queue_setup(): Rx Burst Bulk Alloc Preconditions are satisfied. Rx Burst Bulk Alloc function will be used on port=1, queue=0.
Port 1: 68:05:CA:30:51:B5
Checking link statuses...
Port 0 Link Up - speed 1000 Mbps - full-duplex
Port 1 Link Up - speed 1000 Mbps - full-duplex
Please explain to us about this unexpected situation.
FYI,
Our current OS is CENTOS 7 with latest controller driver from https://downloadcenter.intel.com/download/24411/Network-Adapter-Driver-for-PCI-E-40-Gigabit-Network-Connections-under-Linux- Intel® Download Center
Lspci Info:
# lspci | egrep -i --color 'network|ethernet'
02:00.0 Ethernet controller: Intel Corporation Ethernet 10G 2P X710 Adapter (rev 01)
02:00.1 Ethernet controller: Intel Corporation Ethernet 10G 2P X710 Adapter (rev 01)
Lshw Info:
# lshw -class network
*-network:0
description: Ethernet interface
product: Ethernet 10G 2P X710 Adapter
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0f0
version: 01
serial: 68:05:ca:30:51:b4
width: 64 bits
clock: 33MHz
capabilities: pm msi msix pciexpress vpd bus_master cap_list rom ethernet physical autonegotiation
configuration: autonegotiation=off broadcast=yes driver=i40e driverversion=0.3.30-k firmware=f4.22 a1.1 n40.25 e8000143f latency=0 link=no multicast=yes
resources: irq:17 memory:f5000000-f57fffff memory:f5808000-f580ffff memory:f7580000-f75fffff
*-network:1
physical id: 0.1
bus info: pci@0000:02:00.1
logical name: enp2s0f1
version: 01
serial: 68:05:ca:30:51:b5
<p styl...Ссылка скопирована
- « Предыдущий
- 1
- 2
- Следующий »
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi x710,
Thank you for the post, Just to double check looping the two ports of that X710DA, are you referring to connecting the cable from port 1 to port 2 of the same X710DA? This kind of connection yields limited performance ..
rgds,
wb
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi wb_Intel,
wb_Intel wrote:
Hi x710,
rgds,
wb
Yep, we connect the cable from port 1 to port 2 on same X710DA. Is there any document/note refer to this limited performance case?
Tu
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Tu,
Thank you for the clarification. I will further check on your setup here.
rgds,
wb
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Tu,
Please check if you are using the latest firmware, here is the latest NVMupdate site
https://downloadcenter.intel.com/download/24769/NVM-Update-Utility-for-Intel-Ethernet-Converged-Network-Adapter-XL710-X710-Series Intel® Download Center
thanks,
wb
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
[root@linuxsrv13 Linux_x64]# ./nvmupdate64e
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.24.33.08
Copyright (C) 2013 - 2015 Intel Corporation.
WARNING: TO AVOID DAMAGE TO YOUR DEVICE, DO NOT EXIT OR REBOOT OR POWER OFF THE SYSTEM DURING THIS UPDATE
Inventory in progress. Please wait [.......-**]
Num Description Device-Id B:D Adapter Status
01) Intel(R) Ethernet Converged Network Ad 8086-1572 02:00 Up to date
02) Intel(R) I210 Gigabit Network Connecti 8086-1533 05:00 Update not available
03) Intel(R) I210 Gigabit Network Connecti 8086-1533 06:00 Update not available
Tool execution completed with the following status: All operations completed successfully
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Still 1000Mbps. Issue still there.
Interactive-mode selected
Configuring Port 0 (socket 0)
PMD: i40e_dev_rx_queue_setup(): Rx Burst Bulk Alloc Preconditions are satisfied. Rx Burst Bulk Alloc function will be used on port=0, queue=0.
Done
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi x710,
Thank you for sharing the test results with us.
I have noted this and we will further check on this issue.
Sincerely,
Sandy
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi x710,
We would like to understand more about the network card and your system settings. Please answer details below:
1. Serial number and part number from the white sticker. (See adapter photo http://www.intel.com/support/network/adapter/pro100/sb/CS-031543.htm here)
2. Is the CentOS running on a bare metal system, or in a virtual machine.
If in a VM, what the Virtual Host (ie VMWare).
3. How long is the fiber cable?
4. What is the current version of the NVM on the adapter?
We look forward to your reply.
Sincerely,
Sandy
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Thanks for your replying.
FYI,
1.
2. CentOS 7 is running on a bare metal system.
3. Fiber cable length is 5m.
4. Current version of the NVM on the adapter is 1.24.33.08
5. Firmware version showing after ethtool -i command is
firmware-version: f4.33.31377 a1.2 n4.42 e191b
Tu
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Dear Tu,
Thanks for providing the details. This helps us understand your environment.
The sticker where you can find the serial number is located at the front panel.
Format: 12-digit(MAC Address) 5-digit 6-3 digit number.
We'll wait for your reply.
Sincerely,
Sandy
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Tu,
Thanks for your quick response. I'll check on this and will update you on our findings.
Sincerely,
Sandy
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Tu,
Upon checking, we think that its the driver problem or the driver is not loaded. Please check if you are using the latest driver.
The latest driver is available for download https://downloadcenter.intel.com/download/24411/Network-Adapter-Driver-f or-PCI-E-40-Gigabit-Network-Connections-under-Linux- here.
Hope this help resolve the issue.
Sincerely,
Sandy
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Thanks for your response,
I've installed the latest version and this issue still there .
Currently, I use the ethtool for checking driver version. Is there any tips for deeper diagnosing? Please advice me.
ethtool -i enp2s0f0
driver: i40e
version: 1.2.38
bus-info: 0000:02:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
Tu
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Tu,
Thank you for the update. Will further check on this.
rdgs,
wb
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Tu,
For further diagnostics, please do the following:
ethtool ' with no additional arguments
this can tell the supported link modes and whether auto-negotiation is enabled
thanks,
wb
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
FYI,
Maybe because this ETH-Dev does not support auto-neg, therefore it cannot work at the highest speed, doesn't it?
ethtool enp2s0f0
Settings for enp2s0f0:
Supported ports: [ ]
Supported link modes: 1000baseT/Full
10000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: No
Advertised link modes: 1000baseT/Full
10000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: No
Speed: Unknown!
Duplex: Unknown! (255)
Port: Other
PHYAD: 0
Transceiver: external
Auto-negotiation: off
Supports Wake-on: d
Wake-on: d
Current message level: 0x0000000f (15)
drv probe link timer
Link detected: no
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Tu,
Thank you for the update. let me further check on this.
rgds,
wb
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi
I am facing a similar issue with an X710 I am using at my lab, which is not syncing to speed changes in the link peer.
The ethtool shows no autonegotiation support, and when trying to activate autoneg it replies with error and there are warnings in /var/log/messages.
I am using i40e driver 1.2.38 on CentOs6.5.
[root@pe03-dut ~]# ethtool eth-tg8
Settings for eth-tg8:
Supported ports: [ FIBRE ]
10000baseT/Full
10000baseT/Full
Speed: 10000Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Supports Wake-on: d
Wake-on: d
[root@pe03-dut ~]# ethtool -s eth-tg8 autoneg on
Cannot set new settings: Invalid argument
not setting autoneg
[root@pe03-dut ~]# cat /var/log/messages
May 3 23:32:06 localhost kernel: [59453.619472] i40e 0000:83:00.0: eth-tg8: If you are not setting advertising to 1020 then you may have an old version of ethtool. Please update.
May 3 23:32:06 localhost kernel: [59453.646562] i40e 0000:83:00.0: eth-tg8: Autoneg not supported on this phy
Ofir
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
- « Предыдущий
- 1
- 2
- Следующий »
