Ethernet Products
5678 Discussions
Internal compiler error
Kakos
Hello, recently I am running switchml P4 code on Tofino programmable switch (the code can be found in GITHUB), currently I am using version 9.7.4 of sde, during the compilation process there is an internal compiler error, the log message only shows some WARNING and no other ERROR, and I also asked the question in the official P4 forum, but the reply said the problem would be different depending on the compiler version, and the specific problem might be the P4 code writing, but there is no specific book about the problem, so I would like to seek an answer, thank you very much!
Shaq_Intel
Hi Kakos,
Thank you for reaching Intel Technical Support, As for your question regarding Intel Tofino, it more suit for you to post it at the Embedded Ethernet Communities as the product belong to that section. You can click on the link below for the Embedded forum and post your question there. Sorry for the inconveniences.
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
Shaq_Intel
duansima
hello, have you figured it out?
