Ethernet Products
5821 Discussions
JL82599ES cannot find the device in the system
tomhaha
Hello: The PCB we designed uses JL82599ES to generate twoSFP+optical ports. We do not have an auxiliary power supply, and the input power supply is S0 +12V. The current problem is that the device cannot be found in the system. May I ask: In the absence of an auxiliarypower supply, must the power on timing of JL82599ES also be executedaccording to Figure 11-1 Power and Reset Sequencing in thespecification sheet? Can the MAIN_PW R_O K pin be directly pulled upto+3.3V without an auxiliary power supply? thank you!
Subhashish
Hello tomhaha,
Greetings from Intel !!
Thank you for posting in the Intel Community. We sincerely apologize for the delay in our response. We have received your concern and would like to assure you that assisting you is our top priority.
Could you kindly let us know if the issue has been resolved, or if you require further assistance from us? Your prompt response will greatly help us in diagnosing and resolving the issue as quickly as possible.
We appreciate your patience and understanding, and we look forward to hearing from you soon.
Subhashish_Intel.
MACM
Hi Tomhaha,
Thank you for contacting Intel.
This is the first follow-up regarding the issue you reported to us.
We wanted to inquire whether you had the opportunity to share us the requested information.
Feel free to reply to this email, and we'll be more than happy to assist you further.
Mohammed Ali CM
Intel Customer Support
MACM
Hi Tomhaha,
This is the second follow-up regarding the issue you reported to us.
Mohammed Ali CM
MACM
Hello Tomhaha,
This is the third follow-up regarding the reported issue. We're committed to ensuring a swift resolution and would greatly appreciate any updates or additional information you can provide.
If we don't hear back from you soon, we'll assume the issue has been resolved and will proceed to close the case.
Please feel free to respond to this email at your earliest convenience.
Mohammed Ali CM
