Ethernet Products
5657 Discussões
Missing IntelNetCmdlets
LPong
Principiante
13.108 Visualizações
Hi.
I'm back on this forum, after 4y with my new Asus H470m mobo and I'm pretty disappointed that problem with VLANs is still the same.
However I used VLAN's on with my old mobo. They have been created with standard power shell procedure:
https://www.intel.com/content/www/us/en/support/articles/000035837/network-and-i-o/ethernet-products.html
Yesterday I changed my mobo and CPU but i did not made fresh Windows install. Before that I uninstalled some drivers, LAN as well. After boot I installed fresh drivers including LAN.
After that I tried to use power shell but I get this error.
I tried with Asus LAN drivers, last version of drivers in your page and also with this:
https://downloadcenter.intel.com/download/22283/Intel-Ethernet-Adapter-Complete-Driver-Pack?product=82186
But all installation packages install just drivers I don't have any temp folder where drivers are unpacked, so I can not do this part:
  1. Open the Command Prompt as an Administrator.
  2. Access the folder that is made after having unzipped the Intel® Ethernet Adapter driver package.
  3. Within the Command prompt, go to APPS > PROSETDX > Winx64.  In this folder, run the following command to install the driver along with PROSet and the Advanced Network Settings: DxSetup.exe BD=1 PROSET=1 ANS=1"
And I think that this part is responsible that I'm getting upper error.
Because I don't have folder:
C:\Program Files\Intel\Wired Networking\IntelNetCmdlets
Under "C:\Program Files\Intel\Wired Networking" there is no file/folder at all.
Can somebody help me, how to install "Pro set" to get back IntelNetCmdlet.
Thank you!
1 Solução
Caguicla_Intel
Moderador
13.026 Visualizações
Hello LPong,
Good day!
SW driver package 25.6 is now available for downloads. Will you be able to try it out to check if it will help in fixing the issue?
Intel® Ethernet Adapter Complete Driver Pack
Version: 25.6 (Latest)
Looking forward to hear from you.
Should there be no response from you, I’ll make sure to reach out via phone after 3 business days.
Crisselle C
Intel® Customer Support
Ver solução na publicação original
8 Respostas
Caguicla_Intel
Moderador
13.093 Visualizações
Hello LPong,
Please provide the information below that would help in checking your request.
1.) Kindly confirm that you are using Intel® Ethernet Connection I219-V.
2.) What is the exact Operating System and version used?
3.) Do you encounter any issues or error message while installing the LAN driver?
4.) Can you confirm if you have Intel PROSet Adapter Configuration Utility (ACU) on your system and check if you can create VLAN?
Should there be no response from you, I’ll make sure to reach out after 3 business days.
Crisselle C
LPong
Principiante
13.089 Visualizações
@Caguicla_Intel first of all, thak you for your help.
Yes. I'm using I219-V on  my Asus PRIME H470M-PLUS.
Windows 10 Pro with latest updates.
No.
No, I can't install it. I even don't have option.I tried to install them from here:
https://downloadcenter.intel.com/download/25016/Intel-Network-Adapter-Driver-for-Windows-10?wapkw=intel%20proset%20adapter%20configuration%20utility
At the beggining of installation I probaly had to have these (yellow marked) options? But I only have
"Device drivers"
I'm familiar with IntelPROSet, I have perfect VLAN runing on my second PC (with I217-LM). This picture actually is from another PC, where I installed PROset successfully.
Caguicla_Intel
Moderador
13.084 Visualizações
Hello LPong,
No problem at all, appreciate your swift response.
We hope you don't mind providing System Support Utility (SSU) logs from your system. Currently, we are checking if you are encountering the same issue from link below. We may need to get the Device ID of your Intel® Ethernet Connection I219-V.
https://community.intel.com/t5/Ethernet-Products/Intel-R-Ethernet-Connection-11-I219-V-Unable-to-install-intel/td-p/1187251
Kindly refer to the steps below on how to extract the SSU logs.
a- Go to https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
b- Open SSU.exe
c- Mark the box "Everything" and then click "Scan".
d- When finished scanning, click "Next".
e- Click on "Save" and attach the file to a post.
Hoping to hear from you soon.
We will follow up after 3 business days in case we don't receive a reply.
Crisselle C
LPong
Principiante
13.080 Visualizações
Dear Crisselle,
thank you for further assist.
Yes, I saw post from other user about similar problems, but I was not sure if my problem is the same, so I opened new post.
If you want we can continue there...
My logs are in attach.
Caguicla_Intel
Moderador
13.059 Visualizações
Hello LPong,
Thank you for the reply.
Please allow us to further check on this. We will get back to you as soon as there is any findings but no later than 2-3 business days.
Hoping for your kind patience.
Crisselle C
Caguicla_Intel
Moderador
13.027 Visualizações
Hello LPong,
Good day!
Crisselle C
LPong
Principiante
13.020 Visualizações
I can confirm that installing PROSet and VLANs working with last version.
Thank you Intel!
Caguicla_Intel
Moderador
13.006 Visualizações
Hello LPong,
Thank you for the update.
We are glad to hear that the latest 25.6 version resolved the issue.
Please also accept our sincerest apologies for the inconvenience that this might have caused on your end.
We will now proceed with request closure since you already locked the thread. Your time and cooperation throughout the process is highly appreciated. If you need any additional assistance in the future, please submit a new question as this thread will no longer be monitored.
May you have a great rest of your day!
Crisselle C
Responder
