Ethernet Products
5707 Discussions
NUC d54250wyk win 10 ethernet not working
BHilb
After updating my NUC D54250WYK to windows 10, there has been problems with the ethernet port,(which works fine in win 7)
Symptoms:
If I have been changing settings in my router or settings in the control panel, the connection in between the NUC and router drops.
I have to reboot the router and NUC to get the Ethernet to work again.
I have done every driver update possible, but nothing works.
I have reverted to win 7 and the Ethernet is stable and has not caused any problems?
Is this a known problem and is there a recipe for fixing this issue?
(router is a ASUS RT-AC68U)
Best regards
Bjarne
n_scott_pearson
For Windows 10, you need version 20.2 of the LAN package. You can download it from here: https://downloadcenter.intel.com/download/24198/LAN-Intel-Gigabit-Ethernet-Controller-driver-for-Intel-NUC https://downloadcenter.intel.com/download/24198/LAN-Intel-Gigabit-Ethernet-Controller-driver-for-Intel-NUC. I haven't tried it myself, but folks are saying it worked for them...
BHilb
Marvin_L_Intel
Hello bjarnehilbrecht,
It seems that you were going to do the suggestion given by N.Scott.Pearson, can you please provide us with your findings after doing that?
marving_intel
