Ethernet Products
5077 Discussions
PROSet Cable Tests button grayed out
TomMoz
Updated with the latest driver, restarted, still can't run the Cable Test.
Connection Tests run fine.
Any ideas why?
Windows 10 Pro x64 22H2 latest patches.
PROSet v29.0 installed.
Driver v29.0 installed.
Restarted.
TomMoz
WOW!!!
Is there no limit to how much you prefer to throw the responsibility on other vendors???????
Camel75 wrote: "Latest working (Cable Testing) ProSet is 28.02 for me. In 28.03 and 29 > cable testing grayed out."
So it was working in version 28 and stopped working in version 29!!!
How is that Gigabyte's issue????
This is a software bug that was introduced in version 29!
Please do your job!
Camel75
Hi Pintu !
You want Gigabyte or ASUS to patch your (Intel) PROSet Software ?
I will kindly remind you that i have the same issue with Asus Motherboard (Intel I211AT)... remember ?
Is this a joke ?
TomMoz
Camel75, this is the kind of service we get when Intel is hiring people for the following purposes:
1. Wasting our time as much as possible, so we might give up and go away.
2. Stopping requests from reaching the people who are supposed to fix the bugs.
As we've seen in the 14th gen CPU crash issue, Intel loves blaming the motherboard makers for its own bugs.
Intel Support, please do your job.
Pintu
Hello TomMoz,
Greetings for the day!
We are apologies for the delay response. Please try to update to the latest version 29.1 of the of the Intel® Network Adapter Driver for Windows® 10 and share the result.
And if you want a full installation, click on the provided link and share the status: https://www.intel.com/content/www/us/en/support/articles/000058304/ethernet-products.html before proceeding with updating the latest driver version.
Thank you for using Intel products and services.
Manoranjan.
TomMoz
I installed both the driver version 29.1 and the PROSet software version 29.1, then restarted my computer.
The result is still the same, the Cable test button is still grayed out.
I ran both the Hardware and Connection Status tests:
Hardware Test Results [5/15/2024 20:37:24] :
Register Status :Passed
FIFO Status :Passed
Interrupt Status :Passed
Loopback Test(s) :Passed
_________________________________________
Connection Test Results [5/15/2024 20:38:06] :
Connection Status : Passed
Successfully pinged gateway address xxx.xxx.xxx.xxx (IP hidden)
Cable Link Status : Passed
This device is running at full speed.
I_Nawf
TomMoz, I have no issue with the cabel test version 29.1. Maybe you can try re-installing the application? Or probably the cable?Just giving some ideas.
Nawf
TomMoz
@Camel75 has version 29.1 solved your Cable Test issue?
Camel75
No ! Same results...
I can actually update the driver to latest (14.0.5.0), but everything after ProSet 28.2.02 dont work.
Its quite annoying that intel provides 2 separate files to install drivers and ProSet, but you can not uninstall ProSet only... Its removing also drivers...
ProSet.jpgProSet2.jpgTomorrow i will also latest drivers and ProSet on my older PC (old Asus Motherboard with intel LAN) where with Cable Test you can also almost exact measure the length of the LAN cable...
TomMoz
Yup, downgraded PROSet to version 28.2 and Cable Test is working again.
Tried version 28.3 and it's not working.
It looks like this bug was introduced with version 28.3.
But, keep blaming Gigabyte...
Pintu
Hello Tom Moz,
Thank you for contacting Intel.
We appreciate you reaching out to us regarding the reported issue. As the product was purchased from one of our OEM (Original Equipment Manufacturer) partners, we kindly advise you to contact the OEM's support team for assistance. They will be best equipped to provide support and address any concerns related to the product's warranty coverage.
Feel free to reply to this email if you have any further questions or need assistance. We're here to help.
Manoranjan.
Intel Customer Support
Camel75
Which Product do you mean ? PROSet Software ?
Your Support is ridiculous.
Incompetence Level here is hard to believe...
Thanks for your help !
Bye
Pintu
Hello Tom Moz,
Greeting for the Day!
We are currently awaiting your response regarding the case. If you have any queries or require further assistance, please feel free to respond on the community post. We are more than happy to assist you.
Thank you for choosing Intel products and services.
Manoranjan Das.
TomMoz
You're waiting for my response after taking your hands off your own buggy software and sending me to Gigabyte support again???
What's the purpose for my response if all this support team exists for is to waste the customer's time?????
Pathetic quality and total Incompetence!!!
RyanFeeko
New Contributor II
Hey @TomMoz , i have gone thru all the your and Intel support reply... can see the Intel Support (@Pintu) seems not much helps on your issue. That is very sad to see that.....
As per my checking, i found that there is new release driver 29.1.1.1 version. Maybe you can try if the latest driver fixed the issue. If still the same might need to wait the next major release for the Proset and driver... Hope Intel not remove the cable test option.
You can find below link:
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html
Hope this helps....:D
Pintu
Hello Tom Moz,
In this case, we are not attempting to directly send you to Gigabyte. However, we recommend reaching out to Gigabyte support. Since this specific adapter is integrated with the motherboard, and Gigabyte is the OEM, they may possess more information about it.
Manoranjan Das.
TomMoz
You mean to say Gigabyte may possess more information about why Intel has introduced a bug in PROSet version 28.3 and when Intel is planning to fix this bug in the software Intel has developed?
I'll be super gentle in my reaction and say, I highly doubt that Gigabyte could contribute some useful information about this Intel bug.
Again, please stop wasting our time with something Intel development team needs to solve and stop adding more complexity to something Intel needs to address directly. Why should we ask the OEM questions about bugs that Intel (and you as Intel representative) should answer directly???
Following your logic, maybe I should also contact the store where I bought my motherboard, so they will contact Gigabyte, so Gigabyte will contact Intel????????
Stop insulting our intelligence.
If all you're capable is wasting our time I'd appreciate you not commenting.
Irwan_Intel
Hello TomMoz,
Could you please provide the make and model of the motherboard in question? Additionally, have you been in touch with the motherboard manufacturer regarding this issue?
As per our team update, this limitation could be due to the manufacturer not enabling additional capabilities.
Irwan_Intel
Camel75
Hello Moderator !
Read all posts here and don't waste our time...
Both Motherboards were already mentioned (TomMoz 1st answer and my firs post)
Pintu
Dear TomMoz,
Warm greetings for the day!
We apologize for any inconvenience caused.
Regarding this matter, we have already escalated it to our internal team. Once we receive an update, we will promptly inform you of the status.
Manoranjan
IntelSupport
Community Manager
Hello TomMoz,
Greetings!!
We are currently investigating the issues you have encountered with PROSet and would appreciate your assistance in gathering some specific information to further diagnose the problem.
Could you please provide us with the exact versions of PROSet where you have observed both working and failing behaviors?
Additionally, we kindly request that you perform the following steps to collect PROSet/QV logs:
1)Set the Trace value in the registry:
Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\INTEL\Network Services\NCS2
Set “Trace” to a value of “4”
2)Open PowerShell and run the following command:
(Get-Process -Name wmiprvse | Where-Object {$_.Modules.ModuleName -contains "ncs2provider.dll"}) | Stop-Process -force
3)Attempt to reproduce the issue.
4)Locate the logs:
Logs should be available in C:\Program Files\Intel\Wired Networking\NCS2\
Additionally, please check the Event Viewer for any related errors:
Navigate to Event Viewer -> Windows Logs -> Application & System
Look for errors occurring when the issue is reproduced.
Vishal
Pintu
Hello TomMoz,
Manoranjan.
