Ethernet Products
5654 Discussions
Performance Report on Intel NIC
JLee157
Hello team,
posting here to get a help on finding out a performance report of Intel NIC X710 & XL710
During the last few days, I tried searching Intel NIC performance documents , but still no luck
Anyone can provide or can advise where to go ?
1.Performance Comparison report between Intel NIC and Mellanox NIC- (10, 40GbE)
2.Performance Comparison report between Intel 82599 and X710(XL710)
At least, I would like to get Intel NIC performance report(benchmarking report) on X710 & XL710
(ie throughput per packet size)
Thanks in advance
Any advice would be appreciated.
Hello Jaeyoung,
Thank you for posting in Intel Wired Ethernet Communities. We will look for a performance report on the X710 and XL710. Will also look for specific performance comparisons between Intel and Mellanox network adapters, and 82599 and X710. Please let us know if you have any other questions. Will post an update when available.
Daniel D
Intel Customer Support,
Agent under contract to Intel
JLee157
Many Thanks Daniel for your reply
To be more specific,
I'm looking for Performance evaluation report (or packet loss test) on X710, XL710 itself most of all.
and also,
1.Performance Benchmarking (Comparison) report between Intel NIC and Mellanox NIC- (10, 40GbE)
2.Performance Benchmarking ( Comparison) report between Intel 82599 and X710(XL710)
3.Any commercialized reference for X710(XL710) in both baremetal environment and virtualized environment
and also It would be great If you have any documents showing chipset spec , NIC's registry on X710 / XL710
much appreciate for your help again
Jae
Hello Jaeyoung,
We were able to locate the following information for you:
https://fast.dpdk.org/doc/perf/DPDK_18_02_Intel_NIC_performance_report.pdf Performance test report of 82599, X710 and XXV710
https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/xl710-10-40-controller-datasheet.pdf Chipset spec of X710
Kindly check the ".inf" files included in the driver for NIC registry info, if this is for windows-related registries from the Intel driver. We do not provide competitor reports between Intel and 3rd party NIC. Please let us know if you need any additional information.
Daniel D
JLee157
Many Thanks Daniel ,
The given report seems to be DPDK performance.
What I was expecting is NIC performance report (without DPDK)
Do you also have it?
Jae
Hello Jaeyoung,
Unfortunately we only have performance reports using DPDK drivers. The non-DPDK drivers would not have a noticeable difference in performance. Please let us know if you have any questions.
Daniel D
JLee157
much appreciate Daniel for your help and support
I will get my customer referred to the given reports.
Many thanks again in deed
Jaeyoung
Hello Jaeyoung,
Glad we could be of assistance. Please let us know if you have any other questions.
Daniel D
