Ethernet Products
5821 Discussions
Using EepromARMTool on Nvidia Jetson TX2
IPopa1
We have a problem with eepromARMTool using it on Nvidia Jetson TX2.
We are using your 82574L Gigabit Network Controller integrated on Intel Gigabit CT DESKTOP ADAPTER (EXPI9301CTBLK). Our platform is based on Nvidia Jetson TX2 modul (https://www.nvidia.com/en-us/autonomous-machines/embedded-systems-dev-kits-modules/ https://www.nvidia.com/en-us/autonomous-machines/embedded-systems-dev-kits-modules/) and we use Nvidia Jetson TX2 Developer Kit with integrated PCIeX4 interface.
Currently, 82574L is connected to Nvidia Jetson Tx2 Developer Kit. Operating system on Jetson TX2 is Ubuntu 16.04, kernel version is Linux tegra-ubuntu 4.4.38-tegra.
We have built eepromARMTool application only by running make on source files which you have provided.
When we run app eepromARMTool without arguments we recived expected answer:
Intel(R) Eeprom ARM Tool ARM OTP Programming Tool
Provided under the terms of a CNDA. Do Not Distribute.
Copyright(C) 2013 by Intel(R) Corporation
NIC BUS DEV FUN Silicon Memory Type Present
1 1 0 0 82574 FLASH
But when run app in dump mode, it causes Bus error (core dumped):
Intel(R) Eeprom ARM Tool NVM/OTP Programming Tool
Copyright(C) 2013-2014 by Intel(R) Corporation
Version 0.6.7
dmesg prints:
Unhandled fault: alignment fault (0x92000061) at 0x0000007f7b59e014
Any help will be appreciated.
Ilija
Hi Ilija,
Thank you for posting in Wired Ethernet Community.
We're currently looking into your concern and will provide an update as soon as possible.
Vince T.
Intel Customer Support
Agent under contract to Intel
Hi IIija,
Please submit your concern through Intel(R) Premier Support. Kindly visit this https://www.intel.com/content/www/us/en/design/support/ips/training/access-and-login.html link for access and login information.
Vince T.
Hi IIija,
Please let us know if you have other assistance needed.
Vince T.
