- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi everybody,
I have a ubuntu box with a dual-port 82599EB card, so I have two Physical Functions shown up. Each PF spawns 10 VFs.
One of the applications I am running, bases things on persistent network interface names.
I would like to know whether there is a way to ensure persistent naming of the PFs across reboots, like "eth2" and "eth3".
Sometimes, eth3 comes up as eth23-eth3 and so on.
I have a udev rule that is supposed to give persistent names based on MAC address:
# PCI device 0x8086:0x10fb (ixgbe)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:1b:21:a3:bf:40", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth2"
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:1b:21:a3:bf:41", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth3"
However, for some reason, this doesn't work.
What is happening, I believe, that PFs and VFs are being discovered concurrently. So if a VF is discovered before the second PF, it takes its name (say eth3). Later, when the second PF is discovered, it cannot receive the same name, so it generates a name like ethXX-eth3.
I tried to put a udev rule to give persistent names based on PCI addresses of the PFs:
ACTION=="add", SUBSYSTEM=="net", BUS=="pci", ID=="0000:03:00.0", NAME="eth2"ACTION=="add", SUBSYSTEM=="net", BUS=="pci", ID=="0000:03:00.1", NAME="eth3
But this did not work also. Sometimes, after a reboot, names still get messed up.
Any help is appeciated.
Alex.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Alex,
What you describe is a well-known issue. One that is unfortunately out of the control of we at Intel, and squarely in the hands of the kernel guys.
I'm asking around here if anybody has a script or a solution for you, however thus far I've not magic wand I can provide you. Hopefully somebody a lot smarter than I reads this question and has a solution for us.
- Patrick
p.s.
Have you considered just never rebooting your system?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks, Patrick.
Can you pls elaborate what exactly is the known-issue here? Is it the udev rule not working? Or something else? Perhaps I can take it further to udev developers.
Thanks!
Alex.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I was referring to the order in which devices are enumarated. I'm not familair with the udev rules. I will keep my eyes and ears open; if I find something I'll post it.
I did stumble across this article - that has some similar things your scripts do:
http://www.google.com/url?sa=t&rct=j&q=udev%20fules%20ethernet%20names&source=web&cd=1&ved=0CCQQFjAA&url=http://www.dell.com/downloads/global/power/ps1q07-20060392-Domsch.pdf&ei=Q0O0ToPZNuiQiALx2vw7&usg=AFQjCNHUi1B_3DstiavHNz87lWQRPG8lMA http://www.google.com/url?sa=t&rct=j&q=udev%20fules%20ethernet%20names&source=web&cd=1&ved=0CCQQFjAA&url=http://www.dell.com/downloads/global/power/ps1q07-20060392-Domsch.pdf&ei=Q0O0ToPZNuiQiALx2vw7&usg=AFQjCNHUi1B_3DstiavHNz87lWQRPG8lMA
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
