Ethernet Products
5049 Discussions
Problems upgrading the firmware on XL710 cards
cphil4
Attempting to update firmware on Intel XL710 using XL710_NVMUpdatePackage_v4_50_Linux.tar.gz.
The update fails with the error
Error: Image iSCSI offset exceeds image size (offset=0x65D, image size=0x200)
Driver details:
Driver 1.3.39.1
edora 22 4.1.10-200.fc22.x86_64 kernel
Full details:
6356.328566] i40e: Intel(R) Ethernet Connection XL710 Network Driver - version 1.3.39.1
6356.348081] i40e 0000:81:00.0: fw 4.33.31377 api 1.2 nvm 4.42 0x800018a3 1.108.0
6356.348087] i40e 0000:81:00.0: The driver for the device detected an older version of the NVM image than expected. Please update the NVM image.
6356.426816] i40e 0000:81:00.0: MAC address: 0c:c4:7a:19:69:f6
6356.430917] i40e 0000:81:00.0: SAN MAC: 0c:c4:7a:1a:2d:a8
6356.468210] i40e 0000:81:00.0 ens1f0: renamed from eth0
6356.479710] IPv6: ADDRCONF(NETDEV_UP): ens1f0: link is not ready
6356.558395] i40e 0000:81:00.0: PCI-Express: Speed 8.0GT/s Width x8
6356.564953] i40e 0000:81:00.0 ens1f0: NIC Link is Up 40 Gbps Full Duplex, Flow Control: None
6356.575019] i40e 0000:81:00.0: Features: PF-id[0] VFs: 64 VSIs: 66 QP: 32 RX: PS RSS FD_ATR FD_SB NTUPLE DCB VxLAN PTP VEPA
6356.604972] i40e 0000:81:00.0 ens1f0: NIC Link is Down
6356.618270] i40e 0000:81:00.1: fw 4.33.31377 api 1.2 nvm 4.42 0x800018a3 1.108.0
6356.618274] i40e 0000:81:00.1: The driver for the device detected an older version of the NVM image than expected. Please update the NVM image.
6356.693940] i40e 0000:81:00.1: MAC address: 0c:c4:7a:19:69:f7
6356.697973] i40e 0000:81:00.1: SAN MAC: 0c:c4:7a:1a:2d:a9
6356.734429] i40e 0000:81:00.1 ens1f1: renamed from eth0
6356.756447] IPv6: ADDRCONF(NETDEV_UP): ens1f1: link is not ready
6356.826063] i40e 0000:81:00.1: PCI-Express: Speed 8.0GT/s Width x8
6356.827599] i40e 0000:81:00.1 ens1f1: NIC Link is Up 40 Gbps Full Duplex, Flow Control: None
6356.846738] i40e 0000:81:00.1: Features: PF-id[1] VFs: 64 VSIs: 66 QP: 32 RX: PS RSS FD_ATR FD_SB NTUPLE DCB VxLAN PTP VEPA
6358.417845] i40e 0000:81:00.0 ens1f0: NIC Link is Up 40 Gbps Full Duplex, Flow Control: None
[root@localhost Linux_x64]# ./nvmupdate64e -l nvmupdatelog01.txt
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.25.20.03
Copyright (C) 2013 - 2015 Intel Corporation.
WARNING: TO AVOID DAMAGE TO YOUR DEVICE, DO NOT EXIT OR REBOOT OR POWER OFF THE SYSTEM DURING THIS UPDATE
Inventory in progress. Please wait [*****-....]
Num Description Device-Id B:D Adapter Status
01) Intel(R) I350 Gigabit Network Connecti 8086-1521 03:00 Update not available
02) Intel(R) Ethernet Converged Network Ad 8086-1583 129:00 Update available
Select adapter(s) to be updated (only 'Update available' adapters may be selected
[(comma-separated adapter numbers) | All | eXit]: All
Do you want to save a backup copy of current NIC images? [Yes | No]: No
Update process in progress. Please wa...
st4
New Contributor III
Hi Clivep,
Let me check on this.
rgds,
wb
cphil4
Thank you. This solution has worked wonderfully for us.
