Ethernet Products
5717 Discussions
RECOVERY not available
diancn
I meet Recovery not available today.
# ./nvmupdate64e
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.39.5.5
Copyright(C) 2013 - 2022 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [|.........]
Num Description Ver.(hex) DevId S:B Status
01) Intel(R) Ethernet Converged N/A(N/A) 1572 00:023 RECOVERY not
Network Adapter X710 available
Tool execution completed with the following status: Device not found.
Press any key to exit.
the dmesg result is,
# dmesg | grep i40e
[ 3.412038] i40e: Intel(R) Ethernet Connection XL710 Network Driver
[ 3.420068] i40e: Copyright (c) 2013 - 2019 Intel Corporation.
[ 3.622804] i40e 0000:17:00.0: Firmware recovery mode detected. Limiting functionality.
[ 3.631623] i40e 0000:17:00.0: Refer to the Intel(R) Ethernet Adapters and Devices User Guide for details on firmware recovery mode.
[ 3.650586] i40e 0000:17:00.0: fw 8.84.66032 api 1.14 nvm 8.40 0x8000af82 20.5.13 [8086:1572] [8086:0006]
[ 3.660621] i40e 0000:17:00.0: The driver for the device detected a newer version of the NVM image v1.14 than expected v1.9. Please install the most recent version of the network driver.
[ 3.827925] i40e 0000:17:00.0: MSI-X vector reservation failed: -34
[ 3.839626] i40e 0000:17:00.0: MSI-X not available, trying MSI
[ 3.931201] i40e 0000:17:00.0 ens1f0: renamed from eth1
and the result of nvmcheck64e is,
# ./nvmcheck64e /DEVICES
Intel(R) NVM Integrity Verification Tool
Nvmcheck version 1.39.05.05
QV SDK version 2.39.05.05
Copyright(C) 2012 - 2022 Intel Corporation.
NIC B/D/F Ven-Dev MAC ENA Branding string
1) 023/00/00 8086-1572 ------------ REC Intel(R) Ethernet Converged Network Ad
2) 023/00/01 8086-154B ------------ N/A ------------
3) 023/00/02 8086-154B ------------ N/A ------------
4) 023/00/03 8086-154B ------------ N/A ------------
5) 023/00/04 8086-154B ------------ N/A ------------
6) 023/00/05 8086-154B ------------ N/A ------------
7) 023/00/06 8086-154B ------------ N/A ------------
023/00/07 8086-154B ------------ N/A ------------
9) 023/01/00 8086-154B ------------ N/A ------------
10) 023/01/01 8086-154B ------------ N/A ------------
11) 023/01/02 8086-154B ------------ N/A ------------
12) 023/01/03 8086-154B ------------ N/A ------------
13) 023/01/04 8086-154B ------------ N/A ------------
14) 023/01/05 8086-154B ------------ N/A ------------
15) 023/01/06 8086-154B ------------ N/A ------------
16) 023/01/07 8086-154B ------------ N/A ------------
Is there any method to resolve this problem ?
Thanks in advanced !
diancn
Caguicla_Intel
Hello diancn,
Please share the following information that would help in checking your request.
1. What is the exact Operating System used?
2. Current driver version
3. Current NVM version
4. Are you trying to update the NVM when you encountered the RECOVERY not available error? If no, please share more details on how you encountered the issue?
4. Is there any software or hardware changes prior to issue?
5. Please share the PBA of the adapter. You may refer to the link below on where to find the PBA number. The PBA consists 6-3 digit number located at the last part of the serial number. This would help us identify if you are using an Original Equipment Manufacturer(OEM) or retail version of Intel Ethernet Adapter.
Identify Your Intel® Network Adapter Model Using PBA Number
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-i-o/ethernet-products.html
6. Do you see any Yottamark or BradyID sticker on the adapter? You may refer to the link below to see what the sticker looks like.
YottaMark* and BradyID* Stickers on Intel® Ethernet Adapters
https://www.intel.com/content/www/us/en/support/articles/000007074/ethernet-products/gigabit-ethernet-adapters-up-to-2-5gbe.html
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
Intel® Customer Support
diancn
Hello, Crisselle,
Thank you for replying !
The following is my answer for your question.
RockyLinux 8.6 (In fact, I have also tried almalinux 8.6/rockylinux9.0, the result is same.)
Intel(R) 40-10 Gigabit Ethernet Connection Network Driver - version 2.20.12
Yes. When I reinstall my OS. I meet the network problem, please refer to the result of the dmesg,
so I find the tool nvmupdate64e and it report "RECOVERY not available".
No.
  The PBA number is M13612-002, see also the attanchment picture.
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-i-o/ethernet-products...
  No. I couldn't see any Yottamark/BradyID sticker on the adapter.
https://www.intel.com/content/www/us/en/support/articles/000007074/ethernet-products/gigabit-etherne...
diancn
Caguicla_Intel
Hello diancn,
Thank you for the detailed response.
We can see that you are already using the latest driver version for this adapter. Based on the photos you shared, there is no Yottamark or BradyID stickers on the physical adapter which are authentication labels for retail version of Intel Ethernet adapter. With this, we'd like to set your expectation that we have a limited support for Original Equipment Manufacturer(OEM) Ethernet adapter and it would be best if you can also get in touch with the manufacturer for further support since they have customized drivers, firmware and software to enable or alter features on your card. They are in best position where you can seek assistance so you don’t lose features or customizations of the Ethernet adapter.
Can you share when and where the adapter was purchased? You may need to obtain the NVM update package from your manufacturer and try it out.
Please also let us know how long is the adapter working fine.
We are also sharing list of Supported Operating Systems for Retail Intel® Ethernet Adapters. Unfortunately, RockyLinux 8.6, almalinux 8.6/rockylinux9.0 are not listed as supported OS for X710 adapter.
https://www.intel.sg/content/www/xa/en/support/articles/000025890/ethernet-products.html
Awaiting to your reply.
Crisselle C.
diancn
Hello Crisselle,
Thank you for your help.
I bought the adapter from www.jd.com , a chinese E-commerce platform, last month.
It could work till I reinstall the operation system, it last nearly one month.
I will seek the help from manufacturer/supplier.
Thanks for your information any way.
diancn
Mike_Intel
Hello diancn,
Thank you for the update and understanding. Since you will now contact the manufacturer, we will close the case now. If you need assistance again in the future, please post a new question.
Thank you and stay safe.
Michael L.
