Ethernet Products
5821 Discussions
Re: LANConf tool on ARM
YenLun
Hi @CarlosAM_INTEL
Our project uses this chip 1GbE network (intel WGI210AT-SLJXR-MM925132) in the server.
We
needs to confirm test pattern.
Can you provide test commands?
Peak differential output voltage (Test Mode 1)
Transmitter Distortion(Test Mode 4)
MDI Return Loss(Test Mode 4)
MDI Common-Mode Output voltage(Test Mode 4)
We still need the LANConf for ARM64 platform .
CarlosAM_INTEL
Hello,  @Fikri_Intel:
We need to clarify that this forum is not related to an Intel Embedded Platform (it is related to an ARM platform).
Due to this, the customer request is out of our scope of support.
Please consider this information when you provide the previous suggestion, or transfer any forums to the channel that you mentioned in your previous communication.
@CarlosAM_INTEL.
Fikri_Intel
Hi YenLun,
Thank you for contacting Intel.
We appreciate you reaching out to us regarding the reported issue.
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns.
Therefore, I will be moving this discussion to the respective team.
Fikri
CarlosAM_INTEL
@CarlosAM_INTEL.
YenLun
Hi Fikri,
Thank you for your reply.
We also need 100M function are ready Test Pattern Random data.
YenLun
IntelSupport
Community Manager
Hello YenLun,,
Greetings from Intel!
We request you to post your query in Embedded Connectivity Form, below is the link for the same.
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
Amina
CarlosAM_INTEL
Hello,  @IntelSupport:
We need to clarify that this forum is not related to an Intel Embedded Platform (it is related to an ARM platform), as we mentioned to @Fikri_Intel in our previous message.
@CarlosAM_INTEL.
Fikri_Intel
Hi YenLun,
Good day!
Upon checking, please open an IPS case at premiersupport.intel.com.
After registration, you will be able to open a case on the Intel® Premier Support (IPS) platform and your request will be handled by one of our engineers as soon as possible.
https://www.intel.com/content/www/us/en/design/support/ips/training/welcome.html
We will proceed to close this thread as of now and it no longer will be monitored.
Fikri
jojo8
hi bro:
I also want to know how Lanconf tool can be used in ARM system. would you like to help me too?
