Ethernet Products
5868 Discussions
Regarding ECN Configuration.
Sushrut
We want to configure NVMe/RoCE with ECN (Explicit Congestion Notification).
Can you please share the document for the same?
FYI,
We are using a PCIe card.
Intel Server Board S2600BP and Intel Server Board S2600WF.
Intel Ethernet Network Adapter E810-XXVDA2/E810-CQDA2.
We have configured RDMA using the document 608515-NVM Express over Fabrics for Intel®
Ethernet Products with RDMA.
Sushrut Bhokre
Mike_Intel
Hello Sushrut,
For us to further check the issue, please provide the following details.
  1. What is your OS?
  2. Can you provide more details on why you are setting up this feature?
  3. Kindly send photos of the card on both sides focusing on all the markings for us to check if the card is not an OEM unit.
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
Sushrut
Hi Michael,
1. We are using Red Hat Enterprise Linux 8.6 (Ootpa), Kernel Version Linux 4.18.0-372.9.1.el8.x86_64
2. We have configured NVMe/RDMA. We want to configure NVMe/RoCE with ECN (Explicit Congestion Notification) to measure and eliminate the packet drop happening.
3.
Can you provide ECN configuration for NVMe/RoCE.
Additionally, it would be of great help if you could provide any method/setup for checking packet drop during RDMA transfer.
Sushrut Bhokre
Mike_Intel
Hello Sushrut,
Thank you for the quick reply, however we need to gather more details to further check this inquiry.
  1. It is hard for us to validate the unit from the label, kindly send photos of the unit on both sides of the card for us to validate them.
  2. Kindly generate the SSU log of your system, please download the utility below:
https://www.intel.com/content/www/us/en/download/18895/intel-system-support-utility-for-the-linux-operating-system.html?wapkw=ssu
Michael L.
Sushrut
Hi Michael,
1. It is not possible for us to share the pictures as the NIC cards are already installed.
2. The SSU log of the system is attached below:
Sushrut Bhokre
Mike_Intel
Hello Sushrut,
Thank you for the quick reply. I will further check your inquiry and please give us 2 to 3 business days to provide an update.
Thank you and stay safe.
Michael L.
Mike_Intel
Hello Sushrut,
Upon checking your records and inquiry, we found a similar existing case which is 05546299. Your email address is also copied on this case. Please wait for the update on the case to avoid confusion and duplicate. Because of this, I need to close this inquiry.
Michael L.
