Ethernet Products
5661 Discussions
The following networking device does not have a driver installed PCI\VEN_8086&DEV_1502&SUBSYS_1497103C&REV_04
Hi Guys,
I am trying to deploy 20+ Compaq 6200 PRO's via Windows Deployment Services. Other desktops work just fine 6000 8000... but not this 6200.
When booting in PXE, the Wim file gets loaded and the WDS screen asks me to select deploy or image. When I select Deploy an error displays:
A connection to the deploymentshare could not be made. The following networking device did not have a driver installed:
Meaning It cannot find a driver for the network card. I believe its the "Intel 82579LM Gigabit networ Connection".
I tried every driver pack for it and injected the drivers in to the WIM file to no avail.
I do find a lot of driver packs where the e1c62x64.inf file stated the PCI\VEN_8086&DEV_1502&SUBSYS_1497103C but not with the &REV_04 at the end.
Intel drivers do not even match that far, they get stuck at PCI\VEN_8086&DEV_1502 before being different
Softpaq SP54803.exe does have the best match (PCI\VEN_8086&DEV_1502&SUBSYS_1497103C)
Here's the first bit;
[Intel.NTamd64.6.1.1]
; DisplayName Section DeviceID
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502
%E1503NC.DeviceDesc% = E1503.6.1.1, PCI\VEN_8086&DEV_1503
; HP
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502&SUBSYS_1494103C
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502&SUBSYS_1495103C
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502&SUBSYS_1496103C
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502&SUBSYS_1497103C
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502&SUBSYS_1632103C
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502&SUBSYS_3395103C
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502&SUBSYS_1787103C
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502&SUBSYS_1788103C
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502&SUBSYS_1789103C
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502&SUBSYS_178A103C
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502&SUBSYS_178C103C
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502&SUBSYS_178D103C
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502&SUBSYS_1790103C
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502&SUBSYS_1791103C
[Intel.NTamd64.6.1]
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502
; HP
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502&SUBSYS_1494103C
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502&SUBSYS_1495103C
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502&SUBSYS_1496103C
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502&SUBSYS_1497103C
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502&SUBSYS_1632103C
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502&SUBSYS_3395103C
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502&SUBSYS_1787103C
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502&SUBSYS_1788103C
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502&SUBSYS_1789103C
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502&SUBSYS_178A103C
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502&SUBSYS_178C103C
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502&SUBSYS_178D103C
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502&SUBSYS_1790103C
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502&SUBSYS_1791103C
_____________________________________________________________________________________
SO I tried something I never done before and made an extra entry for the &REV_04 like this:
; HP
%E1502NC.DeviceDesc% = E1502.6.1.1, PCI\VEN_8086&DEV_1502&SUBSYS_1497103C&REV_04
[Intel.NTamd64.6.1]
; HP
%E1502NC.DeviceDesc% = E1502, PCI\VEN_8086&DEV_1502&SUBSYS_1497103C&REV_04
%E150...
DPiro
Hello I have having this exact same issue two years later with WDS and MDT 2012. How did you resolve it? Thank you.
