- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
[root@sriov6-nat src]# modinfo ixgbevf.ko
filename: /ids/PF_RING-7.4.0/drivers/intel/ixgbevf/ixgbevf-4.5.1-zc/src/ixgbevf.ko
version: 4.5.1
license: GPL
description: Intel(R) 10 Gigabit Virtual Function Network Driver
author: Intel Corporation, <linux.nics@intel.com>
retpoline: Y
rhelversion: 7.4
srcversion: 3D55B52908B1B100D355773
alias: pci:v00008086d000015B4sv*sd*bc*sc*i*
alias: pci:v00008086d000015C5sv*sd*bc*sc*i*
alias: pci:v00008086d000015A9sv*sd*bc*sc*i*
alias: pci:v00008086d000015A8sv*sd*bc*sc*i*
alias: pci:v00008086d00001564sv*sd*bc*sc*i*
alias: pci:v00008086d00001565sv*sd*bc*sc*i*
alias: pci:v00008086d00001530sv*sd*bc*sc*i*
alias: pci:v00008086d00001515sv*sd*bc*sc*i*
alias: pci:v00008086d0000152Esv*sd*bc*sc*i*
alias: pci:v00008086d000010EDsv*sd*bc*sc*i*
depends:
vermagic: 3.10.0-693.21.1.el7.x86_64 SMP mod_unload modversions
parm: enable_debug:Set to 1 to enable debug tracing into the syslog (uint)
[root@sriov6-nat src]# lspci
00:00.0 Host bridge: Intel Corporation 440FX - 82441FX PMC [Natoma] (rev 02)
00:01.0 ISA bridge: Intel Corporation 82371SB PIIX3 ISA [Natoma/Triton II]
00:01.1 IDE interface: Intel Corporation 82371SB PIIX3 IDE [Natoma/Triton II]
00:01.2 USB controller: Intel Corporation 82371SB PIIX3 USB [Natoma/Triton II] (rev 01)
00:01.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 03)
00:02.0 VGA compatible controller: Red Hat, Inc. QXL paravirtual graphic card (rev 04)
00:03.0 SCSI storage controller: Red Hat, Inc. Virtio SCSI
00:04.0 Communication controller: Red Hat, Inc. Virtio console
00:05.0 Ethernet controller: Intel Corporation X540 Ethernet Controller Virtual Function (rev 01)
00:06.0 Unclassified device [00ff]: Red Hat, Inc. Virtio memory balloon
00:07.0 Ethernet controller: Red Hat, Inc. Virtio network device
[root@sriov6-nat src]# ethtool -k ens5
Features for ens5:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: off [fixed]
tx-checksum-ip-generic: on
tx-checksum-ipv6: off [fixed]
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: on
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp6-segmentation: on
tx-tcp-mangleid-segmentation: off
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off [fixed]
rx-vlan-offload: on [fixed]
tx-vlan-offload: on [fixed]
ntuple-filters: off [fixed]
receive-hashing: off [fixed]
highdma: on [fixed]
rx-vlan-filter: on [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: on
tx-ipip-segmentation: on
tx-sit-segmentation: on
tx-udp_tnl-segmentation: on
tx-mpls-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off [fixed]
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
busy-poll: on [fixed]
tx-gre-csum-segmentation: on
tx-udp_tnl-csum-segmentation: on
tx-gso-partial: on
tx-sctp-segmentation: off [fixed]
l2-fwd-offload: off [fixed]
hw-tc-offload: off [fixed]
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello wlian17,
Please provide the ixgbe driver version loaded on your system as well as the firmware version of your X540 adapter.
We would also appreciate if you can provide the PBA and serial number of the adapter. You may refer to the link below on where to find the PBA number. Providing the photos of the adapter focusing on the markings (white sticker) found on the physical card will do as well for us to double check on it. The PBA is consist of 6-digit number located at the last part of the serial number, it could help us identify if it is Retail or OEM version on Intel Ethernet adapter.
We look forward to your response.
In case we don't hear from you, we will follow up after 3 business days.
Crisselle C
Intel® Customer Support
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello wlian17,
Good day!
We'd like to follow up the requested information for us to proceed in checking your request.
Awaiting to hear from you.
We will follow up after 3 business days in case we don't receive a reply.
Crisselle C
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello wlian17,
How are you today?
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future.
May you have an amazing day!
Crisselle C
