Ethernet Products
5667 Discussions
Use the x540 network card to turn on the VF function, but the rx_vlan_offload and tx_vlan_offload function cannot be turned off in the virtual machine.
wlian17
[root@sriov6-nat src]# modinfo ixgbevf.ko
filename:    /ids/PF_RING-7.4.0/drivers/intel/ixgbevf/ixgbevf-4.5.1-zc/src/ixgbevf.ko
version:    4.5.1
license:    GPL
description:  Intel(R) 10 Gigabit Virtual Function Network Driver
author:     Intel Corporation, <linux.nics@intel.com>
retpoline:   Y
rhelversion:  7.4
srcversion:   3D55B52908B1B100D355773
alias:     pci:v00008086d000015B4sv*sd*bc*sc*i*
alias:     pci:v00008086d000015C5sv*sd*bc*sc*i*
alias:     pci:v00008086d000015A9sv*sd*bc*sc*i*
alias:     pci:v00008086d000015A8sv*sd*bc*sc*i*
alias:     pci:v00008086d00001564sv*sd*bc*sc*i*
alias:     pci:v00008086d00001565sv*sd*bc*sc*i*
alias:     pci:v00008086d00001530sv*sd*bc*sc*i*
alias:     pci:v00008086d00001515sv*sd*bc*sc*i*
alias:     pci:v00008086d0000152Esv*sd*bc*sc*i*
alias:     pci:v00008086d000010EDsv*sd*bc*sc*i*
depends:
vermagic:    3.10.0-693.21.1.el7.x86_64 SMP mod_unload modversions
parm:      enable_debug:Set to 1 to enable debug tracing into the syslog (uint)
[root@sriov6-nat src]# lspci
00:00.0 Host bridge: Intel Corporation 440FX - 82441FX PMC [Natoma] (rev 02)
00:01.0 ISA bridge: Intel Corporation 82371SB PIIX3 ISA [Natoma/Triton II]
00:01.1 IDE interface: Intel Corporation 82371SB PIIX3 IDE [Natoma/Triton II]
00:01.2 USB controller: Intel Corporation 82371SB PIIX3 USB [Natoma/Triton II] (rev 01)
00:01.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 03)
00:02.0 VGA compatible controller: Red Hat, Inc. QXL paravirtual graphic card (rev 04)
00:03.0 SCSI storage controller: Red Hat, Inc. Virtio SCSI
00:04.0 Communication controller: Red Hat, Inc. Virtio console
00:05.0 Ethernet controller: Intel Corporation X540 Ethernet Controller Virtual Function (rev 01)
00:06.0 Unclassified device [00ff]: Red Hat, Inc. Virtio memory balloon
00:07.0 Ethernet controller: Red Hat, Inc. Virtio network device
[root@sriov6-nat src]# ethtool -k ens5
Features for ens5:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: off [fixed]
tx-checksum-ip-generic: on
tx-checksum-ipv6: off [fixed]
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: on
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp6-segmentation: on
tx-tcp-mangleid-segmentation: off
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off [fixed]
rx-vlan-offload: on [fixed]
tx-vlan-offload: on [fixed]
ntuple-filters: off [fixed]
receive-hashing: off [fixed]
highdma: on [fixed]
rx-vlan-filter: on [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: on
tx-ipip-segmentation: on
tx-sit-segmentation: on
tx-udp_tnl-segmentation: on
tx-mpls-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off [fixed]
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
busy-poll: on [fixed]
tx-gre-csum-segmentation: on
tx-udp_tnl-csum-segmentation: on
tx-gso-partial: on
tx-sctp-segmentation: off [fixed]
l2-fwd-offload: off [fixed]
hw-tc-offload: off [fixed]
Caguicla_Intel
Hello wlian17,
Please provide the ixgbe driver version loaded on your system as well as the firmware version of your X540 adapter.
We would also appreciate if you can provide the PBA and serial number of the adapter. You may refer to the link below on where to find the PBA number. Providing the photos of the adapter focusing on the markings (white sticker) found on the physical card will do as well for us to double check on it. The PBA is consist of 6-digit number located at the last part of the serial number, it could help us identify if it is Retail or OEM version on Intel Ethernet adapter.
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-i-o/ethernet-products.html
We look forward to your response.
In case we don't hear from you, we will follow up after 3 business days.
Crisselle C
Intel® Customer Support
Caguicla_Intel
Hello wlian17,
Good day!
We'd like to follow up the requested information for us to proceed in checking your request.
Awaiting to hear from you.
We will follow up after 3 business days in case we don't receive a reply.
Crisselle C
Caguicla_Intel
Hello wlian17,
How are you today?
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future.
May you have an amazing day!
Crisselle C
