Ethernet Products
5654 Discussions
VMware icen how to enable RoCE v2 in E810-XXV
MustafaB
Hi Folks,
How to enable roce_ena in icen driver ? I'm using
icen 1.6.5.0-1OEM.702.0.0.17630552 INT VMwareCertified 2021-09-23
Notice RDMA enabled but no flag to change the protocol from default iWRAP to RoCEv2.
esxcli system module parameters list -m icen
Name Type Value Description
DRSS array of int Number of queues for Default Queue Receive-Side Scaling: 0/4/8/16 (default = 4)
FWLogEnable array of int Enable firmware logging functionality: 0 = Disable, 1 = Enable (default = 0)
FWLogEvents long Firmware events to log. Binary math required to set all events.(Turn on Events 1 and 5 with input FWLogEvents=17)
FWLogLevel int FW event log level. Values: 0=none, 1=error, 2=warning, 3=normal, 4=verbose. Invalid values: >=5
LLDP array of int Link Layer Discovery Protocol (LLDP) agent: 0 = disable, 1 = enable, (default = 0)
MaxRdmaInts int Maximum RDMA Interrupts (0..112) (default = 16)
NumQPsPerVF array of int Maximum number of queue pairs to be allocated for each VF in the PF (1,2,4,8,16) (default=4)
RDMA array of int Enable Remote Direct Memory Access (RDMA) support, 0 = disable, 1 = enable, (default = 1)
RSS array of int State of NetQueue Receive-Side Scaling: 0 = Disable, 1 = Enable (default = 1, supports RSS on multiple NetQueues)
RxITR array of int RX interrupt interval in microseconds, (-1 = Dynamic ITR, 0-8160 usec = Static ITR) (default = Dynamic ITR)
TxITR array of int TX interrupt interval in microseconds, (-1 = Dynamic ITR, 0-8160 usec = Static ITR) (default = Dynamic ITR)
VMDQ array of int Number of Virtual Machine Device Queues: 0/1 = disable, 2-16 enable (default =
Kind Regards,
Mus>
Caguicla_Intel
Hello Mus,
Please allow us to check your query together with our higher level support. We will give you an update as soon as possible but no later than 2-3 business days.
Hoping for your kind patience.
Crisselle C.
Intel® Customer Support
Caguicla_Intel
Hello Mus,
Thank you for the patience on this matter.
Please see below update from our engineering team.
We noticed that you also submitted an IPS request that was already answered. We are also sharing below answer from your IPS ticket.
For using RDMA, you have to download the irdman driver from the VMware site.
 After loading the RDMA driver(irdman), The NIC will be automatically loaded in ROCEv2 mode.
Please refer to "Driver setup on Host" section in irdman driver release notes for detailed explanation on how switching between ROCEv2 and iWARP happens.
Feel free to let us know if you have questions and clarifications.
Awaiting to your reply.
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
Caguicla_Intel
Hello Mus,
Good day!
This is just a follow up to check if you have read our previous update. If yes, kindly confirm and let us know if you have questions or clarifications on this matter.
Should there be no response, I'll make sure to reach out after 3 business days.
Crisselle C.
Caguicla_Intel
Hello Mus,
I hope this message finds you well!
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
May you have an amazing weekend ahead!
Crisselle C.
Bujar
Dear Mustafa,
I hope you doing well.
Can you please confirm that installing the 'irdman' driver from VMware solved your problem as suggested by Intel Customer Support. I am in a similar situation; if you can confirm, please.
Thank you.
Bujar
