Ethernet Products
5665 Discussions
WGI210 with pin strapping option and no SW programming
HERJER
Hi there,
is it possible to use the WGI210 with some HW pin strapping so we don't have to use SW to program  the device?
Kind regards
Fikri_Intel
Hi HERJER,
Thank you for reaching out to the Intel Community.
We appreciate you reaching out to us regarding the reported issue. Upon checking, the Intel WGI210 does not natively support configuration via hardware pin strapping to bypass the need for software programming entirely. This is because the Intel I210 family relies on an EEPROM or iNVM (integrated Non-Volatile Memory) for its configuration, which is typically loaded during initialization.
For further information, you can refer to the I210 datasheet:
https://www.intel.com/content/www/us/en/products/sku/64402/intel-ethernet-controller-i210it/specifications.html
Fikri
Fikri_Intel
Hi HERJER,
Good day.
Just wanted to follow up with you, kindly let us know if you have further concerns.
Looing forward to your response.
Fikri
HERJER
Hi Fikri,
Everything is fine. Thank you for your response.
Kind Regards,
Sreelakshmi1
Hi HERJER,
Good day!
Thank you for the confirmation. We would like to inform you that we are closing this request, as the query has been resolved.
Please don't hesitate to ask any further questions in the future. Feel free to start a new conversation, as this thread will no longer be monitored.
Sreelakshmi Balakrishnan
Intel customer support Technician
intel.com/vroc
