Ethernet Products
5762 Discussions
X520-SR2. Also possible to connect LR optics?
LM1
Hello community,
I am wondering if it is possible to connect a LR optic to one port of the x520-SR2 card or if it only supports SR optics. The chip should be the same for all X520 models or am I missing something?
Otherwise I guess I have to go along with one X520-LR1 and one X520-SR1 which is more expensive.
Also, I am wondering if the X520 cards support 1Gbps aswell since I wont be able to upgrade both ends simultaneously. It should be backward compatible but I know that some SFP+ Modules for example support 10Gb only.
I hope you can help me or maybe lead to the right direction.
Best Regards
luigima
Hello luigima,
I just moved this discussion to the Wired Ethernet Support Community.
Fred D.
Hi Luigima,
Thank you for writing in Wired Communities. I will further check if X520-SR2 can support LR fiber optic. For the gigabit speed, X520-SR2 can support 1 Gbps data rates if using the fiber optical module. Please refer to page 4 of the product brief
https://www.intel.com/content/www/us/en/ethernet-products/converged-network-adapters/ethernet-x520-server-adapters-brief.html. I will get back to you with the LR optic inquiry. Thank you.
Sharon
Hi Luigima,
You can use LR optical module on X520-SR2. Please refer to additional reference information at https://www.intel.com/content/www/us/en/support/articles/000005528/network-and-i-o/ethernet-products.html
-Can I mix different SFP module types and cables on a dual port adapter from the Intel® Ethernet Converged Network Adapter X520 Series?
Yes. You can install any mix of supported SFP+ optical modules, SFP modules, or direct attach cables on the same dual port adapter. You can plug any supported module into any port.
Sharon
Hi Luigima,
Please feel free to update me if there is other inquiries. Thank you.
Sharon
AMAHE7
Hi Luigima. I had the same question and foung it, Could you please let me know if actually you tested it. Which means did you put your x520-SR2 card to work with both sfps modules (SR and LR) did it work?
