Ethernet Products
5675 Discussions
do_IRQ kernel unable to handle ethernet IRQ
Sherif
We've been having this issue on several of our machines, we get something like
Apr 2 15:12:46 pc kernel: [62804.716320] do_IRQ: 1.34 No irq handler for vector
in the syslog, all network communications are stuck and sometimes I'm unable to establish SSH connections
we are running Ubuntu 20.04 with 5.4.0-163-generic kernel version
the problem is much more pronounced with Intel IGB 5.6.0-k that gets installed with the kernel (or any apt upgrade operation), the problem can happen every 2 days
we manually update our machines to IGB version 5.13.16, the problem happens much less frequently, maybe every 4 weeks, doesn't happen on some machines
it's a very intermittent problem, very hard to catch, is there a way to get more diagnostic information? or maybe some flags that we can turn on in driver build to better identify the problem?
edit:
we have ICO310 Axiomtek DIN rail PCs, with dual I211 ethernet interfaces
01:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
02:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
Azeem_Intel
Hello Sherif,
Thank you for contacting Intel.
I hope you are doing well. Could you please share a snapshot of the defective part with the serial number visible? Additionally, please let us know if this product was purchased separately or with the machine.
Azeem_Intel
Sherif
Thanks Azeem,
The ethernet controllers are built into the motherboard, we're using an ICO310 DIN rail computer with dual ethernet
https://www.axiomtek.com/Default.aspx?MenuId=Products&FunctionId=ProductView&ItemId=17533&upcat=134
I don't know if MAC addresses can help, they are 00:60:e0:79:50:52/53 for one of the computers
we do see the problem on all computers, so I'm not sure if there's one with a defect
i will try to get a computer serial number and some pictures
Azeem_Intel
Hello Sherif,
Thank you for your response. Since you have an Embedded system, we recommend posting your query in the Embedded community forum for assistance.
https://community.intel.com/t5/Embedded-Products/ct-p/embedded-products
Azeem_Intel
