Ethernet Products
5657 Discussions
x710-da4 negotiating lower PCIe LnkSta and LnkCap
ChaiTea
Installed a new x710-da4 in an Ubuntu 16.04 chassis. Updated the firmware. the lspci -vv shows the LnkSta shows  'Speed 2.5GT/s, Width x1'. I have changed slots and machines but the LnkSta and LnkCap show the same info. 1st machine has PCIe 2.0 slots 2nd machine tried has PCie 3.0 slots.
Nics from other vendor show correct LnkSta.
~# lspci -s 0000:10:00 -vv
10:00.0 Ethernet controller: Intel Corporation Device 37d0 (rev 04)
Subsystem: Intel Corporation Device 0004
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 256 bytes
Interrupt: pin A routed to IRQ 16
Region 0: Memory at c8000000 (64-bit, prefetchable) [size=16M]
Region 3: Memory at cd200000 (64-bit, prefetchable) [size=32K]
Expansion ROM at cc000000 [disabled] [size=512K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] MSI-X: Enable+ Count=129 Masked-
Vector table: BAR=3 offset=00000000
PBA: BAR=3 offset=00001000
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop- FLReset-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [e0] Vital Product Data
Product Name: Example VPD
Read-only fields:
[V0] Vendor specific:
[RV] Reserved: checksum good, 0 byte(s) reserved
End
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt+ UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] Device Serial Number bc-74-b5-ff-ff-1e-f2-f8
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 1
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [160 v1] Single Root I/O Virtualization (SR-IOV)
IOVCap: Migration-, Interrupt Message Number: 000
IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy+
IOVSta: Migration-
Initial VFs: 32, Total VFs: 32, Number of VFs: 0, Function Dependency Link: 00
VF offset: 16, stride: 1, Device ID: 37cd
Supported Page Size: 00000553, System Page Size: 00000001
Region 0: Memory at 00000000cc200000 (64-bit, prefetchable)
Region 3: Memory at 00000000cd220000 (64-bit, prefetchable)
VF Migration: offset: 00000000, BIR: 0
Capabilities: [1a0 v1] Transaction Processing Hints
Device specific mode supported
No steering table available
Capabilities: [1b0 v1] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Kernel driver in use: i40e
Kernel modules: i40e
Mike_Intel
Hello ChaiTea,
For us to further check the issue, please provide the following details.
  1. Can you send a photo of your network card focusing on the markings on both sides of the card?
  2. Can you share the link where you downloaded your latest driver?
  3. Can you share the model of the other NIC's that you used that showed the correct settings?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel Customer Support Technicians
ChaiTea
Hello Michael,
Thank you for getting back to me.
Updated the driver from here:
https://downloadcenter.intel.com/download/4237/Ethernet-Administrative-Tools-for-Intel-Network-Adapters?product=83965
I will not have physical access to the machine for a week, but I will try to to get the pictures you want asap.
The Card is definitely 710-da4. is there another way to ascertain the information you want from the markings?
Here the dump of the ethtool and lspci after the driver and firmware update.
:~# ethtool -i enp16s0f0
driver: i40e
version: 2.13.10
firmware-version: 5.15 0x8000275e 1.2829.0
expansion-rom-version:
bus-info: 0000:10:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
:~# lspci -s 0000:10:00 -vv
Read-only fields:
End
IOVSta: Migration-
The other cards that show info as expected are:
1. Ethernet controller: Mellanox Technologies MT28800 Family [ConnectX-5]
2. Napatech A/S NT20E2 Network Adapter 2x10Gb
Appreciate your help.
Chai.
Mike_Intel
llo ChaiTea,
Thank you for the quick reply.
How about the box of the card? The reason why we are requesting for the markings of the card is for us to validate the card.
Michael L.
ChaiTea
I must apologize. Looks like I got the model number wrong. The card is x722-da4. The issue is still the same. I have attached the markings from the box.
Hope it helps.
Mike_Intel
Hello ChaiTea,
Let me further check the issue by collecting the SSU, Please download the System Support Utility from the link below, and attach a log file for us to investigate this issue.
https://downloadcenter.intel.com/download/26735/Intel-System-Support-Utility-for-the-Linux-Operating-System?wapkw=ssu
Michael L.
ChaiTea
Please find the log from ssu attached.
thank you.
Chai.
Mike_Intel
Hello ChaiTea,
I am checking the SSU logs and I cannot see the X722-DA4. Can you confirm if this is the card installed?
The network card present on the SSU is Intel Corporation 82576 Gigabit Network Connection.
Michael L.
ChaiTea
Hi Michael,
It is in there. It shows up as  'Intel Corporation Device 37d0'.  lspci also shows the device the same way.
thanks
Chai.
Mike_Intel
Hello ChaiTea,
Let me further check this issue. Please give us 2 to 3 days to check what is causing this issue.
Thank you.
Michael L.
Mike_Intel
Hello ChaiTea,
While checking the SSU, I just noticed that cards Firmware version is "5.15 0x8000275e 1.2829.0". Here is our recommendation:
  1. Please try updating the firmware to the latest version which is 8.15. Here is the download link: https://downloadcenter.intel.com/download/24769/Non-Volatile-Memory-NVM-Update-Utility-for-Intel-Ethernet-Network-Adapter-700-Series?product=139351
  2. Please provide the model of your board and check if the firmware of the board is also updated. If the board's firmware is not yet updated, kindly update it to the latest.
Michael L.
ChaiTea
Hello Michael,
Is firmware version '5.15 0x8000275e 1.2829.0' not correct? I had done this step before and shows that as the latest. I ran following again today. Notice that it shows this card as up to date.
'03) Intel(R) Ethernet Network Adapter X722-4 5.21(5.15) 37D0 00:016 Up to date'
root@SP2callgen01:~/Intel/NVMU/700Series/Linux_x64# ethtool -i enp16s0f0
driver: i40e
version: 2.13.10
supports-test: yes
root@SP2callgen01:~/Intel/NVMU/700Series/Linux_x64# ./nvmupdate64e
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.35.42.7
Copyright (C) 2013 - 2020 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [*-........]
Num Description Ver.(hex) DevId S:B Status
01) Intel(R) 82576 Gigabit Dual Port 1.2(1.2) 10C9 00:001 Update not
Network Connection available
02) Intel(R) 82576 Gigabit Dual Port 2.1(2.1) 10E7 00:003 Update not
Server ExpressModule available
03) Intel(R) Ethernet Network Adapter 5.21(5.15) 37D0 00:016 Up to date
X722-4
Tool execution completed with the following status: All operations completed successfully.
Press any key to exit.
Mike_Intel
Hello ChaiTea,
Than you for the update. Is there someone onsite who can check the card physically and get the markings? We need to further check the markings to identify the exact model of the card because the link that we provided is the latest firmware. And also, please provide the details of your motherboard and check if the firmware is also update.
Michael L.
Mike_Intel
Hello ChaiTea,
I just want to make a follow up on the information that I requested on my last post. Please update us for us to further assist you.
Michael L.
ChaiTea
Michael,
I haven't had a chance to access the machine recently. I will try to get the picture you need, but are you suggesting the PCIe speed configuration varies across the different "models" for the card? Also can you confirm the firmware I have on the card is correct, please refer to the logs I have provided earlier.
With regards to the machine motherboard, I will try but am not sure if I get you those details. I can tell you that I have tried the same card on two different chassis and both show the same behavior.
BR,
Chai.
Mike_Intel
Hello ChaiTea,
I will countercheck everything once I have the markings of the card and the details of your board. All of the details that we have are from the logs, however when you tried to update the firmware, it gives you a different message. That is why we we are gathering more details.
Michael L.
ChaiTea
Michael,
Can you elaborate on
"however when you tried to update the firmware, it gives you a different message."
I am not sure what you mean by different message?
Is this not correct firmware for the card?
Also the update utility is identifying the card correctly
X722-4
Chai.
Mike_Intel
Hello ChaiTea,
I mean you mentioned on your post that "I ran following again today. Notice that it shows this card as up to date." That is why we will check everything and start from validating the card. I already mentioned this before that the name of the card is different from the logs.
Michael L.
ChaiTea
Hi Michael,
Let me reset the conversation. As I noted earlier when I posed the pictures of the box that I was mistaken about the card I am using. If I have a way to  change the title of the thread I will do so.
1. I thought I had the x710-da4 card, but that was before I looked at the box more carefully. The supplier had sent me x722-da4 card. So that is what I have installed.
2. The issue as narrated in the original post still applies. The card is advertised as PCIeGen3 but it is getting negotiated with 'LnkCap: Port #0, Speed 2.5GT/s, Width x1'
3. Firmware was update initially and hence shows up-to-date on later attempts. All the utilities are identifying the card correctly 722-da4.
thanks
Chai.
Mike_Intel
Hello ChaiTea,
We do understand that, however if you are going to check the link that I provided. It says there that is the latest Firmware for the network card but you said it shows as the latest. We are trying to investigate the cause of this so that we can move forward with the issue. I also want to let you know that this issue and case has been brought to the attention of our engineers. But before we can move forward, I need to confirm that everything is updated including the Ethernet cards firmware and the boards firmware too.
Michael L.
ChaiTea
Hi Michael,
Thank you for the explanation. I was under impression that 8.15 version shown in the link you sent is the version of the the NVMupdate utility. I guess you are suggesting that the firmware version should be 8.15.
I was able to get access to the machine for a little while. I have attached the picture you wanted. I also restructured other cards in the system. I two have two different Intel cards in it. Th other cards an I350 and a X520, show expected lnkspeed, but not the x722. I have attached log from ssu and output of lspci
Also noticed that the nvmupdate utility shows the bus-id incorrectly (shows in decimal) =>
root@SP2callgen01:~/Intel/ssu# lspci -vv | grep Eth
01:00.0 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
01:00.1 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
03:00.0 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
03:00.1 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
pcilib: sysfs_read_vpd: read failed: Input/output error
10:00.1 Ethernet controller: Intel Corporation Device 37d0 (rev 04)
10:00.2 Ethernet controller: Intel Corporation Device 37d0 (rev 04)
10:00.3 Ethernet controller: Intel Corporation Device 37d0 (rev 04)
14:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
Subsystem: Intel Corporation Ethernet Server Adapter I350-T4
14:00.1 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
14:00.2 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
14:00.3 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
16:00.0 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
Subsystem: Intel Corporation Ethernet Server Adapter X520-1
Chai
X722-4
04) Intel(R) Ethernet Server Adapter 1.99(1.63) 1521 00:020 Update not
I350-T4 available
05) Intel(R) Ethernet Server Adapter 0.147(0.93) 10FB 00:022 Update not
X520-1 available
