Ethernet Products
5306 Discussions
z490 Aorus Master - Lost LAN device (225v)
FranzOmz
OS: Windows 11
MB: Z490 Aorus Master
CPU: 10900k​
Ethernet: i225 (probably. Don't know how to check)
After some reboot I lost my LAN connection. Only WIFI is working.
I found that there is no LAN device anymore in device manager.
I tried:
1. Update ALL drivers from the Gigabyte official website
2. Update intel drivers from intel website using manual installation and ther automatic launcher. In case of the automatic launcher it says: No intel LAN device found
3. Tried to update the BIOS to the latest version
4. Tried to flush dns, reset network settings in windows, etc...
5. Have latest windows updates
6. Did a windows reset. Not a hard reset, kept my files, but deleted all the apps.
When I plug the ethernet cable in, I see the light blinking on the ethernet port. But nothing happens.
I asked help from a gigabyte support, but after 4 weeks no response
Don't know what to do and what else to try. I would really appreciate any advice or ideas.
FranzOmz
I found a tip that Gigabyte can share an NVM firmware via support channel. And it should help me to get the LAN card back online.
Is is a possible solution?
Yogaeasvaran
Greeting,
Thank you for contacting Intel Customer Support.
We are sorry to hear about the issue you encountered with the Lan Connection issue.
Since you have tried several troubleshooting, you may try these:
1) Do Clean installation of Latest Drivers. If the issue does not resolve, follow step 2.
2) Please do Hard reset (Clean OS installation).
3) Once done hard reset, please install the latest drivers from intel website.
For us to check the error from the system:
Please provide the SSU logs of your system so we can further check its configuration.
https://www.intel.com/content/www/us/en/support/articles/000008563/ethernet-products.html
Thank You & Regards,
Yogaeasvaran
Intel® Customer Support
Yogaeasvaran
Hello Mr. Georgii,
Regarding your case number 05930542, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Yogaeasvaran
FranzOmz
Hey, sorry for delay. I'm going to perform the clean windows install during the weekend.
It's hard to do during the Monday-Friday, since it is a working PC
Yogaeasvaran
Hello Mr. Georgii,
Thank You for your reply, as you told us that you will perform the Clean Installation for your system on weekend.
May I know the updates and the current status?
Yogaeasvaran
Yogaeasvaran
Hello Mr. Georgii,
Yogaeasvaran
Yogaeasvaran
Greetings Georgii,
Kindly note that as we have not received any response from our previous follow-ups, we will be closing this request #05930542.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Thank You & Regards
Yogaeasvaran
