FPGA Intellectual Property
6669 Discussions
ALTFP_SINCOS - cosine mode
I'm running Quartus 11.0sp1
I think I found an error for the ALTFP_SINCOS megafunction in cosine mode.
For negative inputs the result comes out with the wrong sign.
Example: cos(-0.1) = -0.995.
Since cosine is an even function i.e., cos(x) = cos(-x) it is not that hard to workaround this problem.
I have a question about the workaround/fix (solution id: rd12212011_626) for the ALTFP_SINCOS megafunction in sine mode.
To workaround this, change the <altfp_sincos_variant_file_name>.vhd file, line 22850 as follows:
Change from:
wire_mantissanorm_add_datab <= ( "0000000000000000000000" & mantissanormnode_w(12));
Change to:
wire_mantissanorm_add_datab <= ( "0000000000000000000000" & mantissanormnode_w(11));
Am I supposed to make the same change in cosine mode?
How do you get 0.1 into ALTFP_SINCOS?
I try it with declaration
real rho = 0.1;
But ALTFP_SINCOS cannot accept with real number.
Thanks for your reading, waiting for your reply!
