- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hello, I am investigating the AVALON Bus Protocol as a standard to be used in a RISC-V SoC design.
I understand AVALON to be an OPEN standard but wish to understand what AVALON IP/Macros/RTL are available for licence/purchase to support the SoC development.
Is there a simple link/URL that will show me the available IP or do I need to use a development tool to reveal the available IP library?
Thank you in advance,
Rob Shepherd
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I don't know if this helps, but here are the Avalon specification and the Embedded Peripherals User Guide, which documents much of the IP included in Platform Designer in the Quartus Prime software for working with Avalon interfaces:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Sstrell,
Thank you for this, you have saved me a number of hours searching.
I am very grateful,
Rob
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello again,
(Sorry to ask)
Do you know whether the IP that is described in the guide is available in HDL form or is it a drag and drop thing that is configured and pops out from the Quartus process as a binary for programming FPGA.
The guide is named "Embedded" IP which may mean the IP is embedded in the tool only but section 41.3 (item
Please let me know if you have experience of this.
Thank you,
Rob
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Yes, you can drag and drop and edit the IP as per the guide, and after you connect everything without any warnings/errors, you can generate the HDL.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
The Generate HDL applies to all design in Platform Designer.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
