Looking to understand more about the "GTS AXI Streaming Intel® FPGA IP
for PCI Express* Design Example" for use in Agilex 5, particularly in a PCIe x1 configuration.
I see there's a driver provided per section 2.7 of the user guide (RDC doc. 817713) that's limited in operations per section 2.8.
Wondering - are there other Intel/Altera provided drivers with greater feature set? Are there third-party drivers pairing well that can be recommended?
Thanks in advance,
Hi Matthew,
All the features is as mentioned in section 2.8. Those will be the most common features that use by most of the user.
If you need greater feature set, we would suggest to develop your own custom driver,
I personally suggest https://windriver.jungo.com/ - Third party driver development tools
Also there is a coming webinar where would be helpful to you.
Wincent_Altera
Hi Wincent,
Thank you, this is very helpful and great timing. I'll look a bit further...
Thanks again!
Hi Matthew,
Thanks for your reply, As the issue had address, I will close the notification bell from my sides and left this to public community to add-on if there is any additional information.
If you happen to have any other question , please file a new thread , we will be there to assist.
Wish you have a nice day, Regards,
Wincent_Altera
