I am trying to use the XVCR Toolkit on the Atum A5 by following the user guide
SPEC:
In Section 3.7.2 the clock connections are defined:
I am using PMA clocking, with a Phase Compensation FIFO and 2x Width transfer, which implies the use of o_tx/rx_clkout2, the Word clock and a 2x division factor. Table 61 also suggests we do not need custom cadence gen.
In Section 3.9.6 the reset sequence is defined:
Which implies this snippet should be used at the top level HDL:
always @(posedge system_clk_100) begin
if (system_reset) begin
gts_i_tx_reset <= 1'b1;
gts_i_rx_reset <= 1'b1;
end else begin
if((gts_o_tx_reset_ack==1'b1) && (gts_o_rx_reset_ack==1'b1)) begin
gts_i_tx_reset <= 1'b0;
gts_i_rx_reset <= 1'b0;
end
end
end
In Section 3.11.1, the JTAG connection to the GTS is defined:
Which suggests to define the following snippet in the HPS definition:
.intel_directphy_gts_0_reconfig_address (address_bridge[17:0])
DESIGN:
All of this combines into the following GTS configuration and system definition:
GTS PMA/FEC PHY settings changed from default:
Datapath clocking mode : PMA
TX/RX PMA interface FIFO mode : Register
TX/RX clock clock source : Word Clock
Enable TX/RX_clkout2 port : YES
TX/RX clkout_2 clock source : Word Clock
TX/RX _clkout2 div by : 2
Enable Avalon Memory Mapped interface : YES
Enable Direct PHY soft CSR : YES
Enable Debug Ednpoint on Avalon interface : YES
With the following Qsys connections, and top level RTL connections:
module golden_top(...);
// GTS signals
reg gts_i_tx_reset, gts_i_rx_reset;
wire gts_o_tx_reset_ack, gts_o_rx_reset_ack;
wire gts_o_tx_clkout, gts_o_rx_clkout;
wire [79:0] gts_i_tx_parallel_data;
wire [79:0] gts_o_rx_parallel_data;
// jtag bridge
wire write_bridge, read_bridge;
wire [31:0] address_bridge;
wire [31:0] writedata_bridge;
wire [31:0] readdata_bridge;
wire [3:0] byteenable_bridge;
wire waitrequest_bridge;
wire readdatavalid_bridge;
// reset
end else begin
end
end
end
qsys_top soc_inst (
.intel_directphy_gts_0_i_rx_cdr_refclk_p_clk (REFCLK),
.intel_directphy_gts_0_i_tx_pll_refclk_p_clk (REFCLK),
.intel_directphy_gts_0_i_tx_reset_tx_reset (gts_i_tx_reset),
.intel_directphy_gts_0_i_rx_reset_rx_reset (gts_i_rx_reset),
.intel_directphy_gts_0_o_tx_reset_ack_tx_reset_ack (gts_o_tx_reset_ack),
.intel_directphy_gts_0_o_rx_reset_ack_rx_reset_ack (gts_o_rx_reset_ack),
.intel_directphy_gts_0_i_tx_parallel_data_i_tx_parallel_data (gts_i_tx_parallel_data),
.intel_directphy_gts_0_o_rx_parallel_data_o_rx_parallel_data (gts_o_rx_parallel_data),
.intel_directphy_gts_0_reconfig_write (write_bridge),
.intel_directphy_gts_0_reconfig_read (read_bridge),
.intel_directphy_gts_0_reconfig_address (address_bridge[17:0]),
.intel_directphy_gts_0_reconfig_byteenable (byteenable_bridge),
.intel_directphy_gts_0_reconfig_writedata (writedata_bridge),
.intel_directphy_gts_0_reconfig_readdata (readdata_bridge),
.intel_directphy_gts_0_reconfig_waitrequest (waitrequest_bridge),
.intel_directphy_gts_0_reconfig_readdatavalid (readdatavalid_bridge),
.gts_jtag_master_0_master_address (address_bridge),
.gts_jtag_master_0_master_readdata (readdata_bridge),
.gts_jtag_master_0_master_read (read_bridge),
.gts_jtag_master_0_master_write (write_bridge),
.gts_jtag_master_0_master_writedata (writedata_bridge),
.gts_jtag_master_0_master_waitrequest (waitrequest_bridge),
.gts_jtag_master_0_master_readdatavalid (readdatavalid_bridge),
.gts_jtag_master_0_master_byteenable (byteenable_bridge),
endmodule
The boot output:
TFTP from server **bleep**.**bleep**.xx.x; our IP address is **bleep**.**bleep**.xx.x
Filename 'fpga/soc_system_base.rbf'.
Load address: 0x90000000
Loading: #################################################################
2 MiB/s
done
Bytes transferred = 2031616 (1f0000 hex)
FPGA reconfiguration failed!Command 'load' failed: Error -110
FPGA not ready. Bridge reset aborted!
Did I overlook something? Any help would be greatly appreciated!
Many thanks!
链接已复制
As I understand, you need to make the XCVR toolkit work. You've enabled options and made connections as per the following method:
3.12.2. Using JTAG to Avalon Master Bridge Intel FPGA IP
May I know how are you handling the reconfig_clk and reconfig_reset signals? I don't see them in the code snippet.
I have connected them to the HPS system clock and the system reset.
From the error message I think the FPGA is not fully configured that why it throws error. Can you try configuring the FPGA with a simpler code, without XCVRs first? Also, make sure that the XCVR reference clock is running and stable before and during configuration.
As recommended please check the FPGA configuration first for the issue. I am closing the case now. However, it will still be open for community members to comment on. Please feel free to open a new case if you need more support.
