FPGA Intellectual Property
6669 Discussions
Agilex5 add own IP fails in RiscFree
AnttiLukats
It seems all attempts to add own IP cores fail when accessed from NIOS-V
We did simplesrt possible IP core:
module pio (
input wire reset_rst, // reset.reset
input wire [3:0] avl_mem_address, // word adressing two address bits less
input wire avl_mem_read, // .read
output wire [31:0] avl_mem_readdata, // .readdata
output wire avl_mem_readdatavalid, // .readdatavalid
input wire avl_mem_write, // .write
input wire [31:0] avl_mem_writedata, // .writedata
input wire [3:0] avl_mem_byteenable, // .byteenable
output wire avl_mem_waitrequest, // .waitrequest
input wire avl_clock // avl_clock.clk
assign avl_mem_waitrequest = 1'b0; // we are ready always
assign avl_mem_readdatavalid = 1'b1;
assign avl_mem_readdata = 32'h12345678;
endmodule
But this also fails, when we open memory browser to look at the memory range assigned we get:
[0x800000] Internal error. Abstract command execution failed: An abstract command is currently being executed.
We tried with one 3rd party IP core in VHDL with the same error!
So what is happening and what can be the problem? Adding IP cores from Altera catalog works well.
AnttiLukats
I fixed the problem by removing readdatavalid signals. Now it works in RiscFree. So it was a problem with the IP core.
It seems the new version of the tools are very strict about Avalon protocol.
sstrell
A number of things.
First of all, are you creating this as a custom component in Platform Designer?  How are you connecting it to the processor?
All data transfers in Platform Designer must be synchronous using the clock.  Doing an "assign" like what you've done, there's nothing for the processor to read.
JingyangTeh_Altera
Hi
Is it possible if you could share us your Quartus Project to understand better the connection?
Jingyang, Teh
AnttiLukats
JingyangTeh_Altera
Hi
I’m glad that your question has been addressed, I will now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
