FPGA Intellectual Property
6672 Discussions
Altera DMA throughput calculation?
I have a Cyclone V and I am connecting a DMA read master to an On Chip RAM and the write master to the DDR Controller.
It seems like I am getting 600MB/sec throughput, which looks too much! Is it possible or is there something wrong? How can I calc the max throughput?
The system is running at 100Mhz and my data width is 64 bits. Theorically I could achieve (64*100.000.000)/8) 800MB/sec. So 600MB/sec looks possible. Is this right? I am comparing the onchip data with the ddr data and it matches but it looks to good to be true...
Cheers
First time I've seen someone ask if they're getting too much throughput. :)
The fact that you're checking it on-chip seems promising. The controller does a lot of things to help efficiency. The high-level stuff in the handbook includes:
Command and Data Reordering
Bank Management
Streaming Reads and Writes
Bank Interleaving
Predictive Bank Management
Build-in Burst Adaptor
etc.
Efficiency is always dependent on the reads and writes, but a lot of this smooths out the low corner-cases for much better efficiency.
