FPGA Intellectual Property
6672 Discussions
Altera PLL reconfig - Simulation problem
I am trying to simulate a PLL with a one reconfiguration module. With Quartus and ModelSim I can compile all the system (with the PLL and the reconfiguration module among others) perfectly without any errors. But when I try simulate the system completely ModelSim return this error:
# Loading work.pll_controller(funcional)# Loading work.pll_reconfig(rtl)# ** Warning: (vsim-3473) Component instance "pll_reconfig_inst : altera_pll_reconfig_top" is not bound.# Time: 0 ps Iteration: 0 Instance: /vpg/PLL_RECONFIG0 File: C:/DVI_14/PLL_RECONFIG_sim/PLL_RECONFIG.vhd# Loading altera_lnsim.altera_lnsim_components# Loading work.pll_pxl(rtl)# Loading sv_std.std# Loading altera_lnsim.altera_lnsim_functions# Loading altera_lnsim.altera_pll# Loading altera_lnsim.dps_extra_kick# Loading altera_lnsim.dprio_init# Loading altera_lnsim.altera_pll_dps_lcell_comb# Loading altera_lnsim.altera_arriav_pll# ** Error: (vsim-3033) /build/swbuild/SJ/nightly/17.1std/590/l64/work/modelsim/eda/sim_lib/altera_lnsim.sv(24438): Instantiation of 'arriav_ffpll_reconfig' failed. The design unit was not found.# Time: 0 ps Iteration: 0 Instance: /vpg/PLL_PXL0/pll_pxl_altera_pll_altera_pll_i_640/genblk2/genblk2/arriav_pll File: /build/swbuild/SJ/nightly/17.1std/590/l64/work/modelsim/eda/sim_lib/altera_lnsim.sv# Searched libraries:# C:/DVI_14/simulation/modelsim/rtl_work# Loading work.resolution_gen(funcional)# Loading work.vga_gen(funcional)# Error loading design
Someone knows what can occur?
Thanks in advance.
