FPGA Intellectual Property
Avalon MM Addressing
Hi Guys,
I connected an custom VHDL Avalon MM Master with an Avalon MM Slave in Qsys.
Both Master and Slave are identical except the address with. I tried multiple addresses from the master , but avmm_slave_memory_burst_0 will be always accessed.
Which address has to be used by the master to access the Second Slave??It should be 0x30000 ??????
This should be a very easy task and I don't get it why it don't work. In attachment are also the interface settings .
Like you see in the slave interface settings, the waveform is not showed because of error/warning. But I dont have any message... http://www.alteraforum.com/forum/attachment.php?attachmentid=11135&stc=1 http://www.alteraforum.com/forum/attachment.php?attachmentid=11136&stc=1
Thanks for help
