FPGA Intellectual Property
6671 Discussions
Beats Per Symbol in Custom SOPC Components
Is there anything special that needs to be done in custom sopc components in order for them to convert between bus widths (using varying symbols per beats?)
I am trying to go from a 32 bit to 16 bit video pipeline and have created a pixel converter based on the existing one as the Video Sync Generator appears to be 'immune' to the dynamic bus sizing.
When I try and use my new component however the display is a mess and I can tell from the appearance of the H/Vsync periods on the screen the video sync generator is either being starved of data or just not recieving the SOP/EOP signals correctly.
The existing pixel converter seems to be able to convert from 4x8bit to 1x24bit so I am not sure what I am missing.
Can anyone see anything wrong with my code below?
HDL Code:
module pixel_converter_565_to_666 ( input wire clk, // clock.clk input wire reset, // .reset input wire asi_in0_data, // in0.data output wire asi_in0_ready, // .ready input wire asi_in0_valid, // .valid input wire asi_in0_eop, // .endofpacket input wire asi_in0_sop, // .startofpacket input wire asi_in0_empty, // .empty output wire aso_out0_data, // out0.data input wire aso_out0_ready, // .ready output wire aso_out0_valid, // .valid output wire aso_out0_eop, // .endofpacket output wire aso_out0_sop, // .startofpacket output wire aso_out0_empty // .empty ); assign asi_in0_ready = aso_out0_ready; assign aso_out0_valid = asi_in0_valid; assign aso_out0_eop = asi_in0_eop; assign aso_out0_sop = asi_in0_sop; assign aso_out0_empty = asi_in0_empty; assign aso_out0_data = 0; assign aso_out0_data = asi_in0_data; assign aso_out0_data = asi_in0_data; assign aso_out0_data = 0; assign aso_out0_data = asi_in0_data; // TODO: Auto-generated HDL template endmodule
TCL file:
# +-----------------------------------# | module pixel_converter_565_to_666# | set_module_property NAME pixel_converter_565_to_666 set_module_property VERSION 1.1 set_module_property INTERNAL false set_module_property GROUP "" set_module_property DISPLAY_NAME pixel_converter_565_to_666 set_module_property TOP_LEVEL_HDL_FILE pixel_converter_565_to_666.v set_module_property TOP_LEVEL_HDL_MODULE pixel_converter_565_to_666 set_module_property INSTANTIATE_IN_SYSTEM_MODULE true set_module_property EDITABLE true set_module_property ANALYZE_HDL AUTO# | # +-----------------------------------# +-----------------------------------# | files# | add_file pixel_converter_565_to_666.v {SYNTHESIS SIMULATION}# | # +-----------------------------------# +-----------------------------------# | parameters# | # | # +-----------------------------------# +-----------------------------------# | display items# | # | # +-----------------------------------# +-----------------------------------# | connection point clock# | add_interface clock clock end set_interface_property clock ENABLED true add_interface_port clock clk clk Input 1 add_interface_port clock reset reset Input 1# | # +-----------------------------------# +-----------------------------------# | connection point in0# | add_interface in0 avalon_streaming end set_interface_property in0 associatedClock clock set_interface_property in0 symbolsPerBeat 2 set_interface_property in0 dataBitsPerSymbol 8 set_interface_property in0 errorDescriptor "" set_interface_property in0 maxChannel 0 set_interface_property in0 readyLatency 0 set_interface_property in0 ASSOCIATED_CLOCK clock set_interface_property in0 ENABLED true add_interface_port in0 asi_in0_data data Input 16 add_interface_port in0 asi_in0_ready ready Output 1 add_interface_port in0 asi_in0_valid valid Input 1 add_interface_port in0 asi_in0_empty empty Input 1 add_interface_port in0 asi_in0_eop endofpacket Input 1 add_interface_port in0 asi_in0_sop startofpacket Input 1# | # +-----------------------------------# +-----------------------------------# | connection point out0# | add_interface out0 avalon_streaming start set_interface_property out0 associatedClock clock set_interface_property out0 symbolsPerBeat 1 set_interface_property out0 dataBitsPerSymbol 18 set_interface_property out0 errorDescriptor "" set_interface_property out0 maxChannel 0 set_interface_property out0 readyLatency 0 set_interface_property out0 ASSOCIATED_CLOCK clock set_interface_property out0 ENABLED true add_interface_port out0 aso_out0_data data Output 18 add_interface_port out0 aso_out0_ready ready Input 1 add_interface_port out0 aso_out0_valid valid Output 1 add_interface_port out0 aso_out0_empty empty Output 1 add_interface_port out0 aso_out0_eop endofpacket Output 1 add_interface_port out0 aso_out0_sop startofpacket Output 1# | # +-----------------------------------
