FPGA Intellectual Property
6669 Discussions
Cannot run program "vsim"
When I try to verify a demo design in DSP Builder, I am getting the following error:
"Cannot run program "vsim":....The system cannot find the file specified".
But I have set the path of vsim.exe in the "File\Set Path" of MATLAB window. I can open the Modelsim by typing the command vsim.exe from the directory where it is present through the command window.
If I type vsim in the MATLAB window, it says "undefined variable or function".
Can anyone please help regarding this?
is it set in your system path?
Thanks for the reply.
Do you mean in the Environment Variables?
I set the following:
Variable: vsim
Value: C:\altera\12.0\modelsim_ae\win32aloem
Thanks Tricky. I could able to run it now.
hai visuma,
i'm also facing the same problem.
how did you rectify the issue????
regards
nandak
I just set the path in MATLAB and also added the vsim path in System Environment Variable "Path".
